front struts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2008, 01:51 PM
front struts
I have a 93 nissan sentra, just did the front struts and the whole spring turns when I turn. Is this normal?
Old 02-24-2008, 04:48 PM
Holder350's Avatar
Auto Parts Professional
yep struts capture the springs..so when you take them out the springs come to. If your thinking of putting struts on it, after you get them off you'll need to take them to a shop so they can swap the springs onto the new ones.
Please dont try to do it yourself....unless you want a broken arm or two.
Old 02-25-2008, 06:50 AM
thanks,but I already had the struts out and changed and back in the car. I did them without a shop[got to know what you are doing]. my problem is that the springs are moving when I turn the wheel.
Old 02-25-2008, 07:08 AM
Holder350's Avatar
It all depends on the type of struts that you have on the car I'm not familiar with that car..........but if there is a bearing plate at the top of the strut then yes it should turn with the wheel.
Unless I am mistaken this is the way most cars work.
Old 02-25-2008, 08:18 PM
The Maintenance Geek
Yes, the spring should turn with the strut, otherwise some little old lady wouldn't be able
to do a three point turn, a 146 point turn would be not trouble at all...
K
"Old School" Roadster Front Fenders rcrfly General Rodding Tech 26 06-04-2015 04:57 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
32 ford frame width at front axle centerline Dirty Steve Hotrodding Basics 4 05-15-2006 07:40 AM
Chevy truck Tilt front End! Onestophotrodshop Body - Exterior 0 12-01-2005 11:26 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
