Front susp. help - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-26-2002, 03:57 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post Front susp. help
I'm going to be building another cool cruiser so I need some help. I have a '77 Trans Am that I'm tearing apart. Questions below:
1. Can I use the power stearing unit and etc with a dropped axel front end?
2. Anyone have a stock or lowerd used dropped axel front end for sale or swap, if so let me know please.
HK
Old 08-06-2002, 05:17 PM
Post
depends on front end setup you have i have a 1929nash with a 7"dropped axle and am running a steering box like that but you will need cross steering and clearence around engine to use . im running a straight 6 chevy blown in my car and had plenty of room
Old 08-10-2002, 04:13 AM
Don Meyer's Avatar
Post
I do not understand what you are doing, but if you are putting a str axel under the car you will have trouble w/bump steer unless you use a panyard(sp?) rod to stop side movement.
If I mistood what you are doing,please clarify....Don
Old 08-10-2002, 08:48 PM
Post
Don, I think you understood me correctly. What I'm doing or want to do is use the power stearing unit in my T/A for my rod. The rod will have a tube axle front end simular to a t-bucket or deuce. Just wonderd if it was possible or should I look into getting a vega or other stearing box/powerunit?
HK
