front suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-09-2007, 01:34 PM
front suspension
hi, im 19, i have a 1929 ford phaeton, with an inline 6, and a 9 inch for differential, im wondering what is the best front end for it, im also looking to lower it an what would be the best way to do that, any tips are much appreciated
Old 10-09-2007, 04:02 PM
Notorious's Avatar
Hot rodder, not street rodder!
Well it depends. Do you want the absolute best handling of IFS or do you want to retain the classic hot rod look of a beam or tube live axle? There are a zillion ways to accomplish either. And how deep are your pockets?
Old 10-09-2007, 04:10 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What type of front end are you running now? What kind of look do you want? Old School? Traditional? Modern?
Old 10-10-2007, 11:10 AM
well im looking for it to stay old school looking but also have good handling, im also looking to lower the front end, and ive heard of a suicide front end, or a drop axle, what are these?
Old 10-10-2007, 11:11 AM
Old 10-10-2007, 12:09 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
Here's a pic of both; a suicide spring mount, PLUS a dropped Ford I-beam axle.
A stock Model A would have the spring mounted UNDER the front crossmember.
The suicide mount has a bracket welded to the "front" of the front crossmember, and depending how low you want it you can build that bracket up even higher. So, you could use a non-dropped Ford I-beam stock axle AND get it low by raising the mount up higher than this one.
This car is also using a "dropped" Ford I-beam axle. The 'drop" refers to the S- Bends at the outer end of the axle. A stock Model A axle won't have those S-bends, it will just have a smile shape. A stock 32-48 I-beam will have some drop with a noticable S-bend, but they can be heated & stretched more like the one in the pic. This one also is a "drilled" & "dropped" axle; the holes are done mostly for looks, but also lightens it a bit. A stock Model A axle can also be dropped, if that's what you have already.
Old 10-10-2007, 08:59 PM
Youngster's Avatar
Front suspension
The easiest front end for your A would be a stock type with a dropped axle. I don't know how much fabricating you have done, but this would be mostly just assembly. A touring with a suicide front end tends to get a little bit long in the wheel base.
Putting back together front suspension chirpn69 Suspension - Brakes - Steering 4 05-07-2006 12:48 PM
1978 Mustang front suspension marlene kit car Suspension - Brakes - Steering 8 03-14-2006 07:14 PM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 07:58 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
69 Nova front suspension, plz help onecoomofo Suspension - Brakes - Steering 2 02-01-2004 09:30 PM
