Front suspension for 1930 Model A - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-16-2004, 02:27 PM
vivalosdoors's Avatar
Question Front suspension for 1930 Model A
I have a 1930 Model A and I want to know the easiest way to set up the front end. I have the complet car that is all original. I am planning on buying a new boxed frame that is bare. any suggestions would help asto what i can still use because I am on a budget.
Joe
Old 12-16-2004, 03:55 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Welcome. Being new to the site, you need to be sure to read the "Read Me' posts at the beginning of each forum. The ones here for example recommend that you just post a general introduction here and post tech questions in the appropriate tech forum. This will give you the best chance for a good answer.
It is unclear what you want to do. Do you want to restore the car with stock suspension or upgrade to a more modern suspension? Give more info.
Old 10-08-2015, 12:20 PM
Up grade to modern suspension install v8 and auto tran.
Old 10-08-2015, 12:32 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Don't hold your breath if looking for a reply, this thread is eleven years old.
Semper Fi
Old 10-08-2015, 03:09 PM
da34guy's Avatar
Maybe the OP is still saving up for it, he said he was on a budget!!!!!!!!!!!
Name:	32 roadsters build pics 183.jpg
ID:	249329   Click image for larger version
Name:	32 roadsters build pics 184.jpg
ID:	249337   Click image for larger version
Name:	32 roadsters build pics 179.jpg
