front suspension 52 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2008, 03:46 PM
Hi i've got a 52 chevy 1/2 ton and its just begining the transformation into a rat. I am planning on a 8 inch Z in the rear with a ladder bar/ ladder link setup. The front is parellel leafs over the axle and i don't know what to do to get my ride height down. Also I plan on running it with no fenders so i would like it look good and i dont know if i like leafs on the front. I could Z the front but i would interfear with the rear leaf mounts. What are a few of my options.
Thanks for all your input good and bad
Name:	STA70452 Resized.JPG
ID:	31622   Click image for larger version
Name:	STA70455 Resized.JPG
Old 08-04-2008, 10:23 PM
scr8pin_f100's Avatar
*WARNING* Idiot in Training!
Last journal entry: Jag Front Clip
You said you were shooting for 8" drop in the rear, so am I to assume that you want at least the same if not more in the front? If so then I am not 100% sure that my original thought of a drop axle with mono leafs will work to get you down that low..Someone who has tried it might be able to chime in more on that...I would thing that your only other option would be a suspension kit of your choice..whether that be a Mustang II based, or Volare, or a GM styled full clip...What is your level of fabricating? What are you comfortable with doing?
Hope this helps a little anyways...maybe others will contribute their input...
Old 08-05-2008, 04:26 AM
low
My level of Fabriction is pretty high, i'm a welder by day. I want to say away from the front clip and IFS, I want a more traditional look. I have seen other cars with a single leaf pack parellel with the axle. Is this an option and what donor car could it come from. And i don't really have go 8" down in the rear but I want the option to later.
Thanks for the input
Old 08-05-2008, 03:35 PM
well, to my knowledge no car or truck ran a monoleaf from the factory..You would have to purchase all of it aftermarket.. I have ridden in a couple of F-100's with mono leafs and they were surprisingly not bad..Of course keeping the stock seat in with all of its cushy springs didn't hurt either...Plus the straight axle would look nice if you do go open wheel..Aside from that, I would recommend you checking out Cboy's project journals on here..He did a pretty trick looking set up on his project that looks pretty slick ...But it is a lot of work and geometry I am sure...lol
Keep us posted on what you decide...
Old 08-06-2008, 10:01 AM
radius arms
well after some thought and a ton of research. I think a trianglelated 4-link in the rear is going to be cheaper just as easy to set up. I would like to run it on air bags but my buget might not allow. In the front i want ditch the stock leaf springs and use old style radius arms with air bags hopefully. Is there anyone who has any pics or links on this style front suspension. I don,t trust myself to fab the whole setup so i want buy some prefabed parts.
P.S. & suspension tips for a 52 Chevy? panamracer Suspension - Brakes - Steering 5 04-20-2010 08:35 PM
Best front suspension package for a 53 Chevy pickup zoomie54 Suspension - Brakes - Steering 1 06-06-2007 10:34 PM
Chevy II Front Brake Conversion problem Trevor Horn Suspension - Brakes - Steering 5 04-05-2007 08:10 PM
1950 Chevy Pickup - front suspension? ADBob Suspension - Brakes - Steering 10 03-14-2006 08:34 AM
Rack & Pinion Steering on a Chevy C-20 Suspension? Dusty82 Suspension - Brakes - Steering 3 03-01-2005 09:15 AM
