front suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-27-2005, 06:09 PM
37plydude's Avatar
New Member
Last journal entry: home
front suspension
hello all, simple question. a mustang II front end or a s-10 grafted on?
Robin
Old 07-27-2005, 07:14 PM
Wiki Edits: 49
For what?????
Old 07-28-2005, 06:31 AM
farna's Avatar
Last wiki edit: AMC V-8s Last photo:
Wiki Edits: 14
Yeah, the "target vehicle" makes a big difference! If the frames line up pretty good grafting isn't bad at all. If you're going MII and there is a cross member made for your vehicle, that may be the best way to go. With grafting you also have to worry about mounting everything else. There's a lot more work to do -- body mounts have to be placed just right, etc. If a premanufactured cross member is made, you keep all the original body mounts and such. So how much time do you have, and how much work you wanna put into it?
Old 07-28-2005, 06:33 PM
37plydude's Avatar
New Member
g'day all, well worked my 2nd day at a rod shop near my home . apparently the owner likes how i work. he's suggested a s-10 donor for my 37 plymouth. plus he has offered me use of the shop anytime(just have to clean up afterwards).
phil's done an s-10 to dodge before so looks like that will be my direction i can use the clip,dif, steering column,booster &m/c etc....
also after i finish assembling the jag xk-e we'll be doing a 37 dodge into a rod. so i'll be able to learn on that project
things are really looking good .....my goal is driving to the nsra nats in 06
robin
Old 07-29-2005, 10:32 AM
farna's Avatar
Wiki Edits: 14
Having an experienced guide and access to his shop makes the choice VERY clear, doesn't it?
Old 07-29-2005, 11:10 AM
zonk's Avatar
Home Built Rods No Rules
Last journal entry: Home Made Sheetmetal bender plans
Before doing any cutting I recommend measuring the S-10 clip every which way be sure it will fit and clear your front sheetmetal, also how well the motor fit,radiator, front steer, IMO I'd recommend the mustang 11
Old 07-29-2005, 06:40 PM
37plydude's Avatar
New Member
Zonk, my boss, has done a couple of mopars with the s-10 component. i looked at his 35 packard with a nova sub-frame. looked beautiful. i had to run my hand on the frame to feel the welded areas. it appeared just like the factory had done that-a-way!
i suspect the s-10 is narrower than the nova,so i am sure it will fit inside the fenders.
robin
Repeat of lost thread, what front suspension is this? Wmarden Suspension - Brakes - Steering 5 03-12-2005 07:18 AM
Front Suspension camaro1127 Suspension - Brakes - Steering 4 03-11-2005 10:09 AM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 07:58 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
69 Nova front suspension, plz help onecoomofo Suspension - Brakes - Steering 2 02-01-2004 09:30 PM
