Front Suspension - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-09-2005, 07:54 AM
Front Suspension
I am just now starting a "new" project. Will be building a 1949 Chev. "Delux Sport Coupe" into a "Driver".
In the past I have built one Chev. 1949 1/2 Ton utilizing the suspension and "innards" from a 1978 Camero and restored to "Original" a 1950 Chev DeLux Sport Coupe.
This new project will consist of an injected 350 Chev coupled to the Overdrive Transmission and rear-end out of a 1996 CHev 1/2 Ton pick-up, which I have now in my possession.
I am in need of guidance and reccomendations in the purchase and installation of an Independent front Suspension " hub to hub". I have been impressed with the "Fat Man System", but would like and appreciate any suggestions.
Thanks
Old 12-09-2005, 08:05 AM
As a Moderator here.....I would like to WELCOME YOU HERE...
Independent front suspension is just about the hottest topic discussed here. There are a LOT of different opinions on whose kit is the best and who has the best support after the sale.
I am a straight axle man myself... so I will step aside and let the others answer your questions.....
Again.....WELCOME....
Old 12-09-2005, 01:10 PM
HUH?'s Avatar
Hey Deuce...
Hey Deuce...remember when straight axles WERE the hot setup?
Take for instance my circa 1970 IHRA D/HR '56 Chevy.
Old 12-10-2005, 08:40 AM
What do you mean......WERE THE HOT SETUP ?
They still are......
I am putting the straight axle stuff under my new 32 3W project. Have the body back on.....and working like a busy bee.....
Old 12-10-2005, 08:50 AM
Thanks
I may be mistaken but I believe that the 96 pickup rear end may be TOO WIDE.....to fit under the 49 Chevrolet car. Under a 49 Chevrolet, most rodders use a 58 inch wide rear end. A 60 inch rear end is harder to use and fit decent size tires under the car without rubbing. The 58 and 60 inches are measurement is taken at the wheel mounting flange to the wheel mounting flange.I know that the wheel pattern on the 96 truck rear end is 5 on 5 and none of the IFS kits I am aware of offer that wheel pattern on their kits....so you will have two different wheel patterns on your project...
I mainly responded to put this thread BTTT
Old 12-10-2005, 10:04 AM
1/2 Ton Rear-end
Haven`t even started tearing the pick-up apart, just got through sand-blasting and painting the 49 Frame, used highbuild primer and black acrylic enamel for the frame- looks pretty good to me so far. Since it has been hovering around 15 to 20 degrees here in western Missouri, I have stopped work. I have a rearend out of a 79 "Olds Cutlass" that should work, but wanted the 343 gear ratio for the O-Drive Transmission. Wanted info on Front IFS before I start on the rear-end.
Old 12-10-2005, 10:26 AM
Maybe someone will post their experiences with a IFS conversion on a 49 Chevrolet car. I have never owned one so....I am of no help.
Measure the Cutlass rear before you take it out....my 77 Cutlass rear was 62 inches wide....
Old 12-10-2005, 05:15 PM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
Thanks
Fatman has a nice product but their customer service has been lacking. That is something they have been working to improve. The owner seems like a nice guy.
Can't help with the application in the '49 Chevy car but it worked well in my 1/2 ton. Don't recall if Heidts has one for the '49 but they have a nice product as well.
Deuce - Nice chassis!
Old 12-11-2005, 10:01 AM
Front suspension
I am in the "reserch mode", would appreciate any assistance.
Last one I did, I used an old Camero . Other than requiring quite a bit of time and effort in making the fender wells fit, it worked quite nicely.
Need a list of differant supplier/manufactures for their information . I plan on spending the rest of this winter just in the aquiring of parts and planning, so I can devote full time to the building of the car come springtime.
I am open to any and all suggestions.
Old 12-12-2005, 06:56 AM
The 49-54 Chev cars are definitely in need of replacing the original IFS front. Those cars were lacking in steering and suspension geometry out of the box. Not to mention 60 year old brake technology. Fat-mans set up is a nice piece and there are also several other manufacturers that make exceptional nice stuff. Here is a link off of Progressive Automotive's web site that will show you an install on a 50 Olds race car ( http://www.progressiveautomotive.com/coollinks.htm ). This will give you a good idea on the install and labor portion of it. I would also recommend getting in touch with Bob over at Progressive. He can recommend any geometry changes or even build you a custom front end.
Old 12-12-2005, 02:45 PM
I second the Progressive Automotive suggestion. Bob does a nice job and is a great resource.
Old 03-15-2006, 06:23 PM
johnegoins
i; have used 78 85 cutlass montecarlo etc. front sus. under several 49, to 54 chevy cars thanks johnegoins
Repeat of lost thread, what front suspension is this? Wmarden Suspension - Brakes - Steering 5 03-12-2005 07:18 AM
Front Suspension camaro1127 Suspension - Brakes - Steering 4 03-11-2005 10:09 AM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 07:58 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
69 Nova front suspension, plz help onecoomofo Suspension - Brakes - Steering 2 02-01-2004 09:30 PM
