FRont Suspension Geometery question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2012, 05:13 PM
67MercCat's Avatar
Junkyard Dogg
Hey guys,
I'm doing a front suspension swap on my car and I'm just trying to figure out if a wider track width will give me a steeper radius angle. The goal is to achieve 60 degrees of turning radius with 17 inch wheels.
Thanks
Old 07-11-2012, 05:53 PM
LATECH's Avatar
NO. Wider track requires more area for a turn. Radius increases.
Fact is stranger than Fiction
Old 07-11-2012, 06:10 PM
67MercCat's Avatar
Junkyard Dogg
okay thanks man. how can I increase turn radius without pushing the track width out all while not having the tires rub the frame? smaller tires?
Old 07-11-2012, 06:16 PM
LATECH's Avatar
Add some Caster in the alignment.You wont gain a lot, but it will give some. If you have manual steering , it will make the effort required to steer much higher, especially when you are not moving.
Old 07-13-2012, 09:18 PM
67MercCat's Avatar
Junkyard Dogg
okay thank you, I have power steering. I'm trying to figure out the geometry Vaughn Gittin is using on his 69 Mustang, I wish he had a site that lays out the specs of the car.
'36 Hudson Terraplane Front Suspension Question Wadeamca Suspension - Brakes - Steering 18 09-30-2014 05:35 AM
55 bel air front suspension question new_rat_rodder Suspension - Brakes - Steering 7 11-11-2007 06:09 PM
95 Grand Am Front Suspension Question leejoy Suspension - Brakes - Steering 2 08-26-2007 07:57 PM
Front suspension question telephone man Suspension - Brakes - Steering 7 01-22-2006 05:15 PM
T-Bucket owners - Front suspension question cucumber1949 Suspension - Brakes - Steering 3 01-02-2006 06:17 PM
