Front suspension help, parellel to transverse spring? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-22-2006, 10:39 PM
Last journal entry: Mock up of fenders
I am using the search function, I swear! Found a lot there, but could someone give me an answer from experience?
I am getting (would have gotten today if the gas station safety bars wouldn't have swerved in front of my trailer) a 1950 pickup rolling chassis with two cabs which I have high hopes of making a rat rod out of.
Finally the question, the chassis has parellel leafs in the front, and I want a transverse spring set up. Anyone modified a parellel leaf front for a single transverse spring? I think I almost have it figured out, but I am not sure about how to mount the spring perches.
My idea is to weld batwings on for hair pins, between the old spring perches on the axles and the spindles. I would probably have to grind away some of the "flat" that makes up the spring perch on the axle currently. Could I use some type of a u bolt arrangement as spring perches utilizing the flats where the springs used to fasten? Would I be able to have the axle bored for a common through the axle spring perch or would that weaken it?
Thanks,
CHAZ
Old 07-22-2006, 11:49 PM
willys36@aol.com's Avatar
Wiki Edits: 21
I think you would be $$ and safety and performance and looks and all other ways way ahead buy buying a transverse front axle. Check the ones offered by Speedway Motors. They have all the hardware you will need to install a great looking and safe front end for not that many shekels.
Old 04-21-2008, 09:36 AM
Wiki Edits: 27
spring brackets
I have seen home made brackets welded to the I beam.. questionable because of unknown welding ability and the alloy of the axle and rod used to do the welding .. I have seen brackets that bolt to the 4 bolt holes . some one does sell weld- on brackets but I didn't save the info ...short quarter elliptical springs can work on a lowered rat truck...Zipper motors in Colorado makes neat lakester buckets using that style suspension
55 Chieftain front suspension help! Tim240Z Suspension - Brakes - Steering 9 12-26-2005 02:04 AM
front suspension 38 DeSoto 38 special Suspension - Brakes - Steering 3 06-28-2005 11:36 AM
Rear suspension spring helpers Meteor Suspension - Brakes - Steering 2 09-19-2004 11:24 AM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 06:52 PM
32 hi boy chrome front suspension McDeuce Suspension - Brakes - Steering 3 12-08-2003 07:52 AM
