front suspension id - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2013, 09:02 AM
front suspension id
a customer brought in a 1940 ford, custom hot rod for an alignment,
he does not know what suspension parts are on this car, i am assuming it is a mustangii power steering rack, it needs outer tie rods, i found them in a moog part. we also need to see about specs for this car to align it properly. it does not look like any caster,camber adjustments are possable, the upper and lower control arms, are custom tubular with spring over shock suspension. any pointers about aligning will be appreciated.
Old 04-02-2013, 10:20 AM
sedanbob's Avatar
An introductory post is recommended, and pictures will help tremendously.
Old 04-03-2013, 10:08 AM
S10xGN's Avatar
Gotta love a turbo!
There are M-II front clips and there are M-II based front clips. The problem is, most everything you get now days will be an aftermarket "based" clip and unless you know who's it is, the parts may not be readily available. Pix surely won't hurt, but may not necessarily help either...
Russ
front suspension kay's 51 Suspension - Brakes - Steering 6 04-13-2011 09:48 AM
front suspension jdhanc Suspension - Brakes - Steering 2 01-10-2011 07:29 PM
front suspension ID 1939P7 Suspension - Brakes - Steering 3 09-04-2010 06:21 AM
front suspension fiddyfofoad Suspension - Brakes - Steering 4 12-03-2006 02:30 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
