Front suspension question - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2006, 03:40 PM
registered user
Hello all...........I have a question concerning raising the front end of my 1990 Lincoln Town Car. I realize that this isn't a hot rod, but here is my situation: I replaced the air suspension(rear air bags instead of coil springs)on my Town Car since the air bags had developed a leak, with coil springs for a 1990 Mercury Grand Marquis. I believe I must have ordered coil springs for a limo or a station wagon since after I installed the springs, the rear of the Town Car was jacked up about 3 inches more than the front. I can live with this, but I would really rather have the car a little more level. I would like to raise the front end (coil springs) about 2 inches. Is there an easy/economical way to accomplish this? I'm not that concerned about a higher center of gravity since I don't go that fast around curves, etc. Thanks for any input.
Old 01-18-2006, 07:28 PM
techinspector1's Avatar
Wiki Edits: 326
Wouldn't it be cheaper and easier to install the proper springs in the rear?
Old 01-19-2006, 01:00 AM
2-manytoyzs's Avatar
Start those projects someday
Last journal entry: Divco - has been on the back burner
I would cut the coils in the back before raising the front. Two wrongs dont make a right.
Old 01-19-2006, 01:05 PM
aka Duke of URL
Cutting the rear coils will make it ride harsher. There are custom kits (MONROE) to eliminate LOAD LEVEL SYSTEMS or AIR-RIDE. They will have the correct spring rates.
It may also be possible the front coils are weak. But stock replacements won't give you 2". DETROIT SPRINGS will be able to cure it but is costly.
Old 01-20-2006, 05:02 PM
registered user
Re: suspension question
Thanks for all the input. I guess I could carry 400 lbs. around in the trunk(just kidding!)
Old 01-21-2006, 04:32 PM
boatbob2
400 lbs in trunk
hi,if you are really thinking about putting 400 lbs in the trunk,ive got a 400 lb girlfriend ,that would do us both a favor,id be able to get rid of her and your car would run level .im ready to swap her out NOW !!!
Old 01-21-2006, 04:36 PM
registered user
400 lbs. in trunk
Many thanks for the offer, but somehow I don't think my dear wife would approve!
Old 01-22-2006, 06:15 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
90 % of the time the rear leaks down on a TC, it is NOT the air bags but the leveler switch.
Got a 90, having that situation now.
Putting coils in does actually eliminate the problem though.....
How Do I "Check" My Front Suspension ? ? white66coupe Suspension - Brakes - Steering 1 09-13-2004 06:45 PM
Model A front suspension Alecigio Suspension - Brakes - Steering 11 08-24-2004 08:58 PM
Front pump question Jmark Transmission - Rearend 1 05-12-2004 10:46 PM
1931 Chevy Front Suspension qajim1 Suspension - Brakes - Steering 5 11-13-2003 08:45 AM
Front suspension - 42 Lincoln Continental Yukondude Suspension - Brakes - Steering 1 10-20-2002 11:42 AM
