front suspension rebuild
What is the proper and safe method to remove front springs in order to disassemble front suspension. Is it simply a matter of renting coil spring compressor or are there certain steps to follow for safe removal. The vehicle is a 1973 firebird with a 350 and auto trans, thanks.
What needs to be rebuilt on the front end. I would rent or borrow or buy the spring compresser. Try craigslist or ebay. Then you can add it to your tool collection
I used a similar method on my firebird and truck. Jack up the vehicle high and put on a jack stand. Loosen but don't remove the lower ball joint nut and use a pickle fork (if you are replacing the ball joint) or ball joint removal tool to break the BJ free. Put the jack under the control arm, lift it enough to take any pressure off the nut, remove the nut and then slowly lower the jack. If you are concerned about the spring flying out, you can put a chain through the middle then up around or through the shock tower. Reversing the process works for installing, and if you are putting in lowering springs, you most likely will be able to get it in without the jack. Just be careful and make sure you have a good jack on a firm surface.
| Front Suspension Rebuild Old School 67 Camaro | psy4s | Suspension - Brakes - Steering | 13 | 06-18-2011 06:15 PM |
| front suspension rebuild questions | slow ride | Suspension - Brakes - Steering | 3 | 02-26-2006 10:23 PM |
| Front Suspension 53 Ford Front Clip | PaulNJ53Ford | Suspension - Brakes - Steering | 2 | 08-11-2004 10:12 PM |
| 69 Camaro front suspension rebuild | 69Z | Suspension - Brakes - Steering | 9 | 10-22-2003 08:38 AM |
