front suspention - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-26-2007, 06:04 PM
front suspention
I am currently building a chopped 51 ford, what i would like to no is what would be the simplest conversion, that would allow me to have fnt disc & p.s.? most after market sub frames do not list anything for a 49/51 ford any suggestions? thanks
Old 02-26-2007, 06:05 PM
poncho62's Avatar
Wiki Edits: 5
welcome....I am moving this to the suspension forum.
Old 02-26-2007, 06:55 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The FatMan should have something for it. Yep ....dropped spindles and a disc brake kit for your model Ford. www.fatmanfab.com
Old 02-26-2007, 07:48 PM
fnt suspention
way to go ? manx 56@ aolThanks Poncho.!!!Manx...I have a friend that has a vast collection of fords Im not building a rod, as much as a week end cruiser, bagged rear chopped top ect , would like to have fuel inj, what would you suggest for a motor, I had a 4 cam ford motor but the wireing kit cos 900.00 & very few aftermarket parts are avaiable. motor wise what do you think, 289,302,351, what would be the easy way to go...thanks manx56@aol.com
Old 02-27-2007, 02:14 AM
A friend of mine grafted a '78 Firebird subframe onto a '51 Ford. He used a '65 Nova rear end so the wheels would match, but he had to slightly (no more than an inch) flare the rear wheel openings for tire clearance.
Old 02-27-2007, 05:44 AM
Lost in the 60's
Wiki Edits: 4
Since this is the Suspension forum....I would suggest that you ask your engine questions over in the...you guessed it...the Engine forum.
Correct sequemce for body panel alignment Ripped Body - Exterior 4 10-19-2005 08:14 AM
Hoods not shuting all the way 74_Chevrolet Body - Exterior 5 09-01-2005 07:10 PM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 04:42 AM
mustang front clip swap 2wld4u Body - Exterior 5 11-02-2003 09:07 PM
GM Front Diff. Reliability For Full Time Use. M&M CUSTOM Transmission - Rearend 4 10-31-2003 05:36 PM
