front swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2009, 02:01 AM
front swap
Does any one know if the front suspension of a 53 chevy car will fitt the frame rails of a 50 chevy truck 1/2 ton. I am considering this if it does not require to much fabricating. Welding would not be a problem for me. Would the 53 car suspension be something one could bolt on or? Would i have to change the steering column or would the truck steering be ok, i know the brakes would have to be worked out and so forth i just want to get a feel for this.
Sorry i dont have much experience in these things. If anyone knows of a good book on how to build useing variouse opptions I would be happy with that also. I bought the how to restore your chevrolet pickup book but i need more info if im going to make something happen.
Thank you in advance for any help.
Old 03-13-2009, 02:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
IMHO, there would be no advantage in using an out dated front suspension like that from the '53.
A more popular swap has been the F body or aftermarket clips. Info is readily available on this whole subject, you'll need to research it further.
Front end swap for a 50 willys wagon gmwillys Suspension - Brakes - Steering 1 12-08-2006 10:21 AM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
1960 Chevy truck front disc brake swap importeater Suspension - Brakes - Steering 1 07-10-2003 12:16 PM
40-47 PU front sheet metal swap jalopy45 Body - Exterior 2 02-11-2002 09:16 AM
40-47 PU front sheet metal swap jalopy45 Body - Exterior 0 01-30-2002 02:29 PM
