front tilting hood - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2007, 04:33 PM
front tilting hood
I have a 26T with a 3 piece hood.It hinges on the right side since the top is attached to the one side cover I can't run with just the top part as I would like to sometimes.Does any one have plans to make the hood hinges that makes it go up and tilt forward? Or any suggestions? And please don't tell me where I can BUY set-ups for $3or$400.00..
Old 02-22-2007, 05:04 PM
late 80s buicks had front tilt hoods those hinges may be the setup for you and there about 30-40 at the jy
Shane
Old 02-22-2007, 05:25 PM
I don't think I can use any stock hinge because a Model T has nothing in fron to bolt to.I thought I saw one somewhere that had flat or angle running from the radiator cover back to the firewall on both sides and some kind of hinge set-up attached to them,but I don't remember where I saw it or any details
Removing "trim bump" ini 'glass fenders S10xGN Body - Exterior 12 01-31-2006 09:47 PM
FiberGlass Cowl Hood Trav Body - Exterior 7 10-23-2003 10:24 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
gm front suspension in a 53 Studebaker wheel-7 Suspension - Brakes - Steering 1 08-15-2003 08:13 AM
TILTING HOOD HINGES 34psyco Hotrodders' Lounge 1 11-06-2002 12:28 PM
