front tires - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2012, 05:02 PM
front tires
i have a 1925 t roadster. 1956 ford p/u spindles 4" droped axle from CCR. tires are 6 degree camber. /__\ front end shakes violently when i hit a bad spot on the freeway at about 60 or 70. goes down the road great. no trouble with steering or turning . WHAT DO I DO
Old 02-09-2012, 06:25 PM
6 degrees camber and you have to ask? Have it aligned properly. Also check for anything loose. Last thing check bump-steer. good luck
Old 02-10-2012, 04:42 AM
cal1320's Avatar
I would call CCR and see if the axle and spindles are compatible. Just because the king pin dia is the same does not mean they will work together. The king pin angle may be different between them. If CCR says yes, then look to see if the spindles are on the wrong side. 6 degrees is too much.
Old 02-10-2012, 07:08 AM
delawarebill's Avatar
front end
wow thats alot of camber... u got a solid axle so it ain't easy to fix.. if fairly new try to exchange it... do a 1/8" toe in. check air pressure, 32# is toooooo much for a lite car. do u have shocks??
Old 02-10-2012, 10:29 AM
Canzus's Avatar
a red wool sock on his dinger
What is the castor set at??
Old 02-11-2012, 08:27 AM
S10xGN's Avatar
Gotta love a turbo!
Yes, lack of positive castor would be the problem. Camber problems will just wear out the tires quicker...
Russ
Old 02-11-2012, 06:34 PM
Canzus's Avatar
Russ
True, but it will go around a corner better...
front tires 38 ford pliers Suspension - Brakes - Steering 3 10-06-2011 07:55 AM
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
front tires, sportsman 72chevelle Garage - Tools 3 09-30-2004 02:30 PM
front tires bob myers General Rodding Tech 9 04-30-2003 10:34 AM
front tires bob myers Suspension - Brakes - Steering 0 04-23-2003 08:54 PM
