front tires 38 ford - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2011, 12:10 AM
front tires 38 ford
will 15" 60 series on 8" wide rims fit on bus. coupe with 4+ " dropped axle???
Old 10-06-2011, 05:43 AM
Irelands child's Avatar
Probably not - they will most likely hit the tops of the fenders going through bumps and the sides in turns.
Irelands child
Old 10-06-2011, 07:44 AM
In addition to being extremely difficult to turn.
Old 10-06-2011, 07:55 AM
I forgot to add - my '31 has Yokohama AVS 205-60x15 on 15x6 wheels. And as Deuce mentioned, it is a "bit stiff" turning at slow speeds.
Irelands child
Gasser front tires? jlscheele Hotrodding Basics 9 09-12-2010 01:05 PM
34 Ford chassis w/MII front end - front tires rub heyjude076 General Rodding Tech 4 04-09-2009 07:46 PM
camaro front tires njbloodline666 Suspension - Brakes - Steering 4 05-01-2004 06:37 PM
front tires bob myers General Rodding Tech 9 04-30-2003 10:34 AM
front tires bob myers Suspension - Brakes - Steering 0 04-23-2003 08:54 PM
