Front of Transmission leaking fluid? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-01-2010, 09:52 PM
I have a 1973 Javelin 6 cylinder engine with a manual 3 speed transmission. I have recently pulled the motor and found the bell housing with a lot of transmission lube on the bottom. The only thing I can find in the transmission to seal the fluid is a gasket directly behind the yoke. I replaced this just a few years ago with a small amount of permatex sealant but it is leaking again. The problem keeps recurring.
Is there anything else I can do to stop the front of the transmission from leaking fluid?
Old 04-02-2010, 02:46 AM
Wiki Edits: 85
Yokes never have gaskets. They constantly flex as your driveline length changes.
So what are you talking about?
Old 04-02-2010, 07:04 AM
He might mean the input shaft seal?
Old 04-02-2010, 10:10 PM
My bad, said yoke meant bearing retainer.
My bad I used the wrong name. I meant the bearing retainer that the throw out bearing rides on has a gasket between it and the transmission housing.
Old 04-03-2010, 03:28 AM
ericnova72's Avatar
More for Less Racer
IIRC there is no actual shaft seal, just an oil slinger behind the bearing retainer, most 60's and 70's 3 and 4 speeds are this way. In order to keep oil from coming out the front you have to drive the vehicle on a regular basis so the slinger can keep the oil thrown back into the case. You also have to be careful to not get too much oil in the trans or the level will be high enough to run out past the slinger, be sure to find out the exact capacity of your trans from a service manual. Some are 1/8" below the fill plug and not running back out the fill plug, if it is full of oil high enough to match the level of the input shaft it will run out the front even if driven daily.
Also make sure the breather vent is clear if the trans has one, if the vent is blocked the trans builds pressure inside as it warms up(just like an automatic or a rear axle housing does) and push fluid out. Make sure you didn't put the bearing retainer back on upside down, some have a small relief hole in the edge to vent the trans or a relief pocket to allow oil drain back into the trans.
Old 04-04-2010, 10:03 PM
Some manual transmissions do have an oil seal inside the front bearing retainer, toward the rear. Saginaw 3- & 4-speeds, for example.
Old 04-04-2010, 10:41 PM
oil leak
i have had many manual transmissions apart. All of them had a seal in the front bearing retainer. That is what the release bearing runs on. Try off roading without a seal in the front of the trans.
Old 04-05-2010, 01:56 AM
ericnova72's Avatar
More for Less Racer
None of the Muncie or early Borg-Warner 4-speeds have a seal in the front bearing retainer. The Muncie's have a combination oil slinger/lert-hand thread retaining nut. I'm just saying the 3-speed in his Javelin could be with or without a front shaft seal in the bearing retainer and what to look for if that is the case.
Old 04-05-2010, 10:19 AM
prostreet6t9's Avatar
Differential/Driveline
That Transmission should be the T14 and it does have a input seal. Google National#482208. There is supposed to be a gasket in between the Brg retainer and the Trans case also. You could always pick up some gasket material at your local parts store and make one.
Old 04-05-2010, 10:26 AM
The Borg warner T10 4 speed uses that same 482208 input seal in the 65-74 Amc's.
Transmission Fluid Spraying out of the Dipstick tube Double_v23 Transmission - Rearend 7 01-01-2009 03:14 PM
Front Transmission Seal Popped? BRSleeper2 Transmission - Rearend 3 07-13-2007 05:32 PM
Leaking 1940 Ford Transmission CSammon Transmission - Rearend 4 05-10-2006 09:42 PM
Leaking transmission fluid from the starter???????????? mk231975 Transmission - Rearend 5 12-08-2003 07:24 PM
leaking transmission cooler lines crshrmn3 Transmission - Rearend 5 08-27-2003 07:26 AM
