Front wheel bearing/hub - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-21-2012, 02:02 PM
mitmaks's Avatar
Last journal entry: Grille
Is there a way to remove front hubs on FWD car without press?
Old 10-21-2012, 02:58 PM
poncho62's Avatar
Wiki Edits: 5
I have never needed a press to remove mine...Undo the axle nut, remove the bolts and knock it out.......What car are we speaking about?
Old 10-21-2012, 04:15 PM
BOBCRMAN@aol.com's Avatar
If you are talking changing the bearing. Most modern FWD systems use a press apart system. First the hub is pressed from the center of the bearing. Then a snap ring is removed from the housing and the bearing is pressed out.
To install is the reverse.. Sounds simple.. In reality.. Cars in the rust belt are usually rusted up solid. The hub seldom presses from the bearing without destroying the races and internals. Removing the rusted solid snap ring from the housing can be a very frustrating procedure..
Then there's the customer.. Who has tried to get that extra mile on a bad bearing assenbly.. Everything is rusted/galled/welded up or impossible to get apart.. Then he has to buy a complete new assembly..
Old 10-28-2012, 08:45 PM
I've had very good luck using the "Hub-Shark", it's a 10" fine-threaded shaft with an assortment of flat plates and cups. On a Honda, remove the wheel/caliper/rotor..use a heavy slde hammer to remove the hub, cut the outer bearing race from the hub on the bench..then back at the spindle,seperate the lower balljoint from the lower control arm,push out the driveshaft,remove the cir-clip retaining the bearing. Now use the Hub-shark to remove the bearing. Reverse procedure for install.
Truth be told, after removing the ABS sensor, tie-rod and upper Balljoint...you could have the spindle in your hands ready for the press...
Removing Wheel bearing hub on 1997 Saturn SW1 67Elcamino Suspension - Brakes - Steering 3 03-12-2012 11:16 PM
54 chevy Series 1 3600 front wheel hub Old Surveyor Suspension - Brakes - Steering 1 02-06-2011 08:36 PM
Front wheel bearing question Don Lyon Transmission - Rearend 3 07-28-2008 07:50 PM
Proper Front wheel bearing torque Tonythefish Suspension - Brakes - Steering 7 01-29-2007 01:28 PM
Tri5 front wheel bearing replacement Stroker56 Suspension - Brakes - Steering 3 04-14-2006 05:36 PM
