Front wheel bearing question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-28-2008, 10:02 AM
Non Hot Rod related,neighbor has a 79 Chevy 4 wheel drive p/u. Local tire shop told him front bearings needed packing. I thought they were lubed from the front wheel drive differential. It does have "Warren "hubs. Thanks in advance.
Old 07-28-2008, 10:08 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Most of them have two sets of bearings like any other front hub...these need to be packed...also there is a set of needle type caged roller bearings behind the hub that need a little wheel bearing grease...you have to remove the spindle to get to those. It would be good if he could get a Chiltons manual for his truck to help him with this project.
Old 07-28-2008, 02:14 PM
F&J F&J is offline
Last journal entry: 32 Ford cabriolet conversion/windshield
...and you'll need the special 4x4 socket with the 4 tangs to remove the nuts that hold the bearing in. Auto parts stores stock them.
Old 07-28-2008, 08:50 PM
Wheel bearing question
Thanks HenryHighrise And F&J for the quick replys. We are of to the Village tommorrow to get a Manual and the right socket. Your responses are greatly appreciated.
master cylinder interchange runn141 Suspension - Brakes - Steering 7 05-03-2009 06:15 AM
Wheel bearing.... SouthernRodder Suspension - Brakes - Steering 1 12-30-2007 09:14 AM
right front wheel locks up madtech Suspension - Brakes - Steering 7 07-08-2005 11:37 PM
Wheel bearing repair ? jamn50 Suspension - Brakes - Steering 2 12-22-2004 08:23 PM
Gm Wheel Bearing Problem scott011422 Suspension - Brakes - Steering 6 07-11-2003 07:41 PM
