Front Wheel Bolt Pattern? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2006, 06:19 PM
texastomeh's Avatar
HELP!!!
Does anyone out there know the front wheel bolt pattern on a 1980 Buick Riviera?
I know that it is five-lug, but don't know the spacing - and no, I don't have it to measure.
Appreciate any help.
thanx,
texastomeh
Old 08-02-2006, 06:22 PM
Wiki Edits: 31
5 on 4.5" spacing I belive. it may be 5 on 5", just measure from the back of the first stud to the center of the third stud, that's your bolt spacing, even on the hub where the rotor fits will work.
Old 08-02-2006, 06:28 PM
el pollo's Avatar
It's shady under this tree...
5-4.75 or 5-115 depending on whether it's rear wheel drive or wrong wheel drive.
RWD = 5-4.75
FWD = 5-115
Old 08-02-2006, 06:51 PM
Twisted Minis's Avatar
A different breed
Last journal entry: New Truck
RWD = 5-4.75
FWD = 5-115
Its a GM car, so this is correct.
Old 08-03-2006, 09:14 AM
texastomeh's Avatar
THANX GUYS!!!!
texastomeh
aftermarket axle bolt pattern carsmetalsusa Transmission - Rearend 4 01-23-2006 10:48 PM
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
Looking wheel bolt pattern info Huskinhano Suspension - Brakes - Steering 5 01-19-2005 05:17 PM
bolt pattern change opel gt AngliaBob Suspension - Brakes - Steering 2 01-13-2005 05:42 PM
body panel alignment gmonkey Body - Exterior 5 09-01-2003 06:50 PM
