Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front Wheel Cylinders On a 67 Impala
Old 08-25-2009, 01:01 PM
BowTiePride's Avatar
BowTiePride BowTiePride is offline
Chevy to the death!
As far as I've ever noticed the rears were always held in by the two bolt setup, but he front, you had to take off the 15/16" pin at the top to the backing plate, and the cyl popped right out. Had to take off the brake line at the frame so the flex hose could come through the backing plate so I could stick it in a bench vise and use some leverage to get off the brake hose (not enough room in behind while attached, and stuck on VERY good). Next up:THM350 swap and toss the powerglide
