Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - front wheel v8 question?
Old 02-02-2013, 02:11 AM
painted jester's Avatar
painted jester painted jester is offline
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
Thought you might be interested about another front wheel drive big block
I think the Cady trans-axle and Torinado trans-axle are the same? Cant remember this many years later? I owned a 67 Torinado And and ran it at Detroit dragway the traction was unbelievable!
Jester
Developed with help from General Motors engineer John Beltz, the Hurst Hairy Olds was built to be a showcase for the then-new chain-driven automatic trans axle of the 1966 Oldsmobile Toronado as well as a rival to the Hurst Hemi Under Glass. There were doubts in the automotive press as to the strength of such a system; the Hairy Olds was designed to dispel these doubts.
The Terrifying Toronado:
Hurst installed not one but two 425 in³ (7 L) Oldsmobile engines and Toronado transaxles both front and rear; a pair of drag parachutes were mounted in the stock taillight positions and four-wheel disc brakes were fitted as well. Two engines meant two of virtually everything in the cockpit related to the operation of the car, including two cable-operated shifters, two tachometers, two sets of oil pressure and temperature gauges and even two accelerator pedals. Additional power was provided via a Cragar Equipment-modified 6-71 GMC supercharger atop each engine, each burning a blend of nitromethane and alcohol. Weight was reduced through the use of aluminum body components and Plexiglas windows. The result was a 2400-horsepower, four-wheel-drive exhibition drag racer which smoked its front and rear tires down the length of the race track with times in the eleven-second range.
The tremendous amount of power at the front wheels caused massive torque steer, resulting in difficulty in keeping the car in a straight line.
A front wheel drive Pic
http://www.hotrodders.com/forum/atta...1&d=1359792448
The 4 wheel drive Terrifying Toronado had a cousin from the other side of the country in the Hurst Hairy Olds. Built in a similar fashion for the 1966 season, the car (a front wheel drive Olds 442) reportedly was built to showcase the bulletproof qualities of the then-new chain-driven automatic transaxle of the '66 Toronado, which had its skeptics in the automotive press. After all, if it could harness the power of a supercharged engine, it should do well in stock configuration, right? (Truth be told, although the front drivetrain was essentially stock, the right-hand axleshafts were swapped for left-hand units because they were stronger, and the torque converters were beefed up, but those are minor points.
