front wheels lock up when turning - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2005, 10:59 PM
montea's Avatar
tryn to learn
i just got my 88 Firebird with a 6cyl. insured it yesterday.
when i take a sharp turn fully locked or almost fully locked, backing up or going forward(like say in a parking lot or turning around on a street) my front wheels skid when theres a little gravel on the road. i tested on clear pavement and had the wheels fully locked and there was a clunk clunk clunk... at very low speed of course like crawling. this car does not like to turn.. almost feels like the rear end is a Spool, but i know does not have one. Anyone know what the problem is? Thanks
Old 04-22-2005, 11:26 PM
montea's Avatar
tryn to learn
i just jacked up 1 side of the car at a time in the front and locked the wheels both ways and they seem to spin really good, didnt scrap nothing and doesnt look like anything would bind. i jacked it up by the bottom of the a-arms so the suspension doesnt decompress and not be like it would be if it were to have the wieght on the suspension like normaly
i noticed the front drivers side has some play in the bearing and the passenger side has just a tinny little bit. that wouldnt be the problem would it? i will be replacing those the bearings on monday hopfully. along with front sway bar end links and the rear sway bar end links. the end links on the rear the bolts snaped off of them so the sway bar is not connected
Old 04-23-2005, 02:36 AM
advanced design's Avatar
Just havin' fun.....
Last journal entry: Wheels and tires
If the tire is not hitting and the caliper is not rubbing the wheel (look for witness marks) it might be the toe setting.
Old 04-23-2005, 05:34 AM
poncho62's Avatar
Wiki Edits: 5
Most cars get better traction on the tires in a straight line. When turned, the tires just don't bite as well. Also, when turned, the weight is shifted on and off the fires a bit.
What have you got for front tires?
Old 04-23-2005, 08:11 AM
montea's Avatar
tryn to learn
my front tires are fairly worn out and cracked, im going to replace those on monday hopefully to if i can find a shop to do it
Old 04-25-2005, 10:58 AM
johnsongrass1's Avatar
Race it, Don't rice it!
What you have is a consequence of bump steer and castor. The proper name is Ackerman Effect. It comes from the inner tire of the corner gaining toe out as you further turn the wheel. GM has added this feature to give you a better "on center" feel with Castor as well as a improved bump steer characistics for a more stable feel at road speeds. You won't have a much Ackerman at higher speeds when the suspension is in compression. In other words, to make the car feel like it handles better, GM has changed the alignment settings. This is a side effect of those settings.
Old 04-25-2005, 01:15 PM
montea's Avatar
tryn to learn
ohhhh so its normal... thats good. last night i swaped on a set of good tires to try and it helped alot but still slided. right at the moment im getting tires put on my wheels at a shop... $83 frigen bucks to install 2 tires, balance 4 wheels, and install new air valves! and i brought them my own tires to put on... WHAT A RIP OFFF! GRRRR and of course they didnt tell me the price till after i took them outa my car...
Classic Hot Wheels Good Condition or New COndition ArchonRacing Engine 2 02-22-2005 12:19 AM
Powerglide not turning the wheels hotrod66_57 Transmission - Rearend 13 11-16-2004 04:16 PM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
1965 Impala Front End Suspension Problem EazyDuzIt102 Suspension - Brakes - Steering 2 03-29-2004 05:52 PM
rear wheeles lock before front krangar Suspension - Brakes - Steering 2 02-20-2003 01:02 AM
