-   -   Frontend Vibrations 47 Ford 4dr sedan (http://www.hotrodders.com/forum/frontend-vibrations-47-ford-4dr-sedan-226725.html)
echo1947 12-01-2012 09:16 PM
I have a 47 ford 4 dr flathead six I restored several years ago. The frontend is vibrating now.. Tires are balanced. Original shocks are working
Any ideas where I start looking to fix the problem.
The first picture is where I started. Second is the finish… runs great except for the front end vibrations
http://img.photobucket.com/albums/v1...7fordstart.jpg
http://img.photobucket.com/albums/v1...rdfinished.jpg
familyguy 12-01-2012 09:20 PM
vibration
Need to know when the shake comes in and goes out,or if it starts slow and gets worse throughout.
echo1947 12-01-2012 09:30 PM
comes in around 30 goes out around 15.... any help
thanks for quick response...
echo1947 12-01-2012 09:32 PM
It sounds like tire balancing but the tires are balanced and ok..
echo1947 12-01-2012 09:37 PM
I get the impression the tires are bouncing up and down. Haven't tried to see if speed will take it out.
It's not a pleasent experience.... Real rough ...
