Hotrodders Bulletin Board
#2
re: Frost Plugs
high temp RTV works best.
the orange stuff. |
#3
re: Frost Plugs
Personally I like the Permatex Aviation "Super 300" form a gasket.
Permatex® Super 300® Form-A-Gasket Sealant Slow drying, non-hardening sealant designed to resist heat transfer fluids such as oil or antifreeze. Temperatures range from -65?F to 425?F (-54?C to 204?C). Resists antifreeze, aviation fuels, high-detergent oils and lubricants. Suggested applications: Use to seal precut gaskets or close machined parts. Just my personal choice. tom
Ya cain't fix stoopid, but ya kin TAX it! |
#4
re: Frost Plugs
And it cleans up easily with alcohol. |
#5
re: Frost Plugs
Good stuff! |
#6
re: Frost Plugs
Never heard them called frost plugs before, always freeze plugs. I doubt a frost would do much damage to your engine, but a freeze sure would if you didn't have any
Vince
Here's to you DoC, you will always be here. My project 34 http://www.hotrodders.com/forum/34-...ght=34+progress |
#7
re: Frost Plugs
This has been beat to death on here, but I couldn't resist. The CORE plugs are not intended to pop out if the coolant freezes. They are on the block as a means of removing the core sand from the casting process.
I have seen blocks split from deck to pan and the plugs were still in their original places. |
#8
re: Frost Plugs
THANK YOU...THANK YOU...THANK YOU... |
Back to top |
Similar Threads for: "Frost Plugs"
| Cam Bearings and Core Plugs (SBC 350)89 | gandl2123 | Engine | 15 | 03-26-2007 03:06 AM |
| changed plugs and now the motor is missing | 71javelin | Engine | 8 | 12-10-2006 06:30 PM |
| DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ? | SCHOONER | Engine | 9 | 10-29-2006 09:25 PM |
| SBC Still fuel fouling plugs, Losing my mind! | 67 Deuce 4 Me | Engine | 9 | 09-02-2005 08:56 PM |
| Rant: Bosch Plugs Cost me $300.00 | Rolm | Engine | 7 | 07-22-2004 09:50 PM |
