Locate new bolts before starting?
Soak 'em down good. |
Got A Torch??
Use a torch to losen up the bolt. That's the way I loosen up bolts and nuts so I don't butcher up the part I want to use.
Heat the bolt itself, let it cool, then remove. Use new bolts. Try to move the bolt tightening it first by just a whisker, then try to loosen.
Also do what "56" said but if it stars to break free tighten then loosen the bolt. Do this repeating it as you loosen it more. This way the threads will clean up and they won't gall and break the bolt. Use lots of penetrating oil. This should do it!!!
Heat, impact gun, clean the threads, lots of penetrating oil. ................
Ontario Rodders |
Yep! Time for the heat.
To add, WD40 is not penetrating oil and it doesn't work well in this application. Use PB Blaster or something similar.
I use..."Break Away"....made by Knights, I believe....good stuff.
Ontario Rodders |
| Ford Radius Arm Bushing Repair | dmorris1200 | Suspension - Brakes - Steering | 0 | 05-03-2003 04:09 PM |
| Hey '59 Ford | Kevin45 | Hotrodders' Lounge | 2 | 01-10-2003 03:16 PM |
| Whatever happend to these guys? | hot_rod_kid | Hotrodders' Lounge | 20 | 12-17-2002 09:20 AM |
| I need a '50s Ford PU pittman arm. | willys36@aol.com | Suspension - Brakes - Steering | 3 | 12-15-2002 06:53 AM |
| Ford Race Engine | BarbWire | Engine | 7 | 10-18-2002 11:38 AM |
