Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 06-22-2005, 12:39 AM
David Skelton David Skelton is offline
Frozen Brakes
I have a 1968 Mustang Fastback that had been sitting for 12-13 years.
All the brakes are "Locked" or "Frozen" Is there a easy way to unstick
the hubs for inspection for probably replacement of original drum brakes?
Thanks
Dave Skelton
Old 06-22-2005, 01:51 AM
KULTULZ's Avatar
KULTULZ KULTULZ is offline
aka Duke of URL
 KULTULZ's barnstar
re: Frozen Brakes
By frozen, I am assuming that the car is off the ground (jackstands) and no wheel (front especially) will rotate?
I would start by opening the wheel cylinder bleed screws to relieve any possible hydraulic pressure (frozen MC). At the front, take a large pry bar and insert between the lugs and see if you can free those. The rear may have frozen brake cables and require a different procedure.
If still locked, you will have no choice but to remove the bearings and pull the hub off with a puller. Try to back off the star adjuster before this. If the adjuster is frozen, you may have to take a hammer and chisel and knock the adjuster from between the shoes.
Actually, it is going to be about the same procedure for the rear. The only other factor is the possibility of the cables having frozen. Again, knock the star adjusters out to try and relieve shoe pressure.
A lot is going to be damaged, but there is no other way.
Old 06-22-2005, 09:02 PM
Bumpstick's Avatar
Bumpstick Bumpstick is offline
Hammer and a torch
re: Frozen Brakes
Remove wheel... On a 45 degree angle to and on the edge of the drum hit it with a 3-4lb shop hammer several times all the way around... Rust and dust will fall but your hub will turn...
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Frozen Brakes"
Brakes !! NO Brakes !!! Sampson Suspension - Brakes - Steering 9 05-30-2005 08:23 AM
Drum brakes smelling bad nitsud08 Suspension - Brakes - Steering 5 04-11-2005 05:15 AM
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 9 03-08-2005 08:23 PM
Drum Brakes WildOne Introduce Yourself 1 12-03-2004 09:41 PM
streetrod brakes bigbadchev Suspension - Brakes - Steering 2 03-10-2004 06:02 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
