Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Frozen clutch?
Thread: Frozen clutch?
Old 06-27-2012, 08:02 PM
Dougie Dougie is offline
Unfortunately it's stuck in nuetral and the pedal won't depress. I told him that he might try disconnecting the slave cylinder pushrod from the actuator arm and then lightly press the pedal to see if the slave moves. At least that would confirm its a mechanical problem and not something in the hydraulics. It be a heck of a lot easier if it was hydraulic. But he should be able to slide it into a gear without the clutch and then maybe try these ideas.
