frt seat - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-08-2011, 09:12 PM
frt seat
what is the best fit for a 31 5 window coupe/bench seat? it has corvette buckets but there to low for me
Old 09-09-2011, 06:31 AM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Some guys have used a middle seat out of a van. Take your tape to the pick-a-part and see if one of those may work..If your seats are too low and otherwise ok then you can make some risers to go under the seat rails to bring them up to a more comfortable height..
Sam
Old 09-09-2011, 07:30 AM
Irelands child's Avatar
I'm using some upholstered Barrett bomber seats in my '31 roadster. I raised them with a framework and some adjuster so they fit, height wise just right for me at 6'4". Not cheap by the time you get them plus add the adjusters and frame, but work which the Glide Engineering pair didn't as they were TOO high.
ONE OF EACH
BOTH
FRAME WORK BEING BUILT
I ended up by having to raise them a bit more with the 1" oak pieces you see so I could get my knees straighter. Painted and installed, work fine - for me
Dave W
Irelands child
Old 09-09-2011, 07:51 AM
delawarebill's Avatar
seating
in a bucket the middle seat from the chry mini van fits very good... this might be an option for ya..
Old 09-09-2011, 01:15 PM
ogre's Avatar
the 'Duracell Project'
if the corvette seats work well for you
just build a pedestal to raise them up.
i raised the seats in my truk 6'' to gain much needed leg room
Old 09-09-2011, 01:21 PM
they sit low and are hard,just picking someone brain thats been there
Old 09-09-2011, 03:16 PM
35terraplane's Avatar
Seat
You could raise them, and when you redo them have more padding put in. You have all the holes drilled and everything, risers are not that hard to make, just have them tilted back a little to get the seat right or just keep putting them in and adjusting until you get a feel you like, don't worry about the hardness, that will be taken care of when they are recovered.
Bob
Old 09-09-2011, 03:45 PM
DanTwoLakes's Avatar
Wiki Edits: 22
There's only so much you can do when adding foam to a Corvette seat. You'd have to have the seat covers remade, including changing the listings to provide more depth which would not be cheap. Corvette seats are not that great anyway, especially older ones. These seats had an inch of foam added to them, and there wasn't room to do more. They're still not very comfortable.
Old 09-09-2011, 04:02 PM
Seats
Dan you were next on my list, I was going to suggest that he PM. you. If anyone knows it's you.
Bob
Old 09-09-2011, 08:08 PM
Wiki Edits: 22
Thanks, Bob. Those seats are out of my wife's '77 Corvette, and I guarantee they're just not comfortable. I would hate to drive more than 100 miles sitting on them. But.....I freely admit I'm not a Corvette fan.
Old 02-14-2012, 01:44 PM
frt seat
I have a bench seat and I need buckets for 31 Ford 5 window coupe, I am 6'2" 254 lbs and I need lower bucket seats, what colour are your vette buckets? my bench seat is red and new? If you still have them and they are red or black, where are you located?
Bench Seat Swap To Bucket Seat Help arnellwest Hotrodding Basics 11 03-28-2011 11:50 PM
What car Did This Seat Come Out Of rollenhard Interior 7 08-26-2010 01:08 PM
once I cut my seat... cutthroatkid Interior 3 10-18-2009 12:11 PM
What should we do with this seat? DanTwoLakes Interior 43 06-12-2007 06:21 AM
tri five car seat 56-210 Interior 1 08-11-2004 08:15 PM
