FT360 .....ideas, thoughts, suggestions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-24-2003, 01:30 PM
Moby302's Avatar
Psychotic
Hi, I am pretty new, here, well I have been coming here for a while but don't often post, however I read the thread in the 'Lounge' from AKM, "what yall think of me" and I like the replies on there, you sound like a stand up bunch of guys. Ok, brown nosing over . We have just got a FT360, basicially for free, [wonder why ] and we were thinking of putting it in our 72 ranchero, I don't think size will be a problem altho ours has an inline 6 in at the moment, they did come out with 351C's and the 360 is not that much bigger. I am more interested in what you guys think can be done to this engine, I believe with the right stroking/boring, cam, carb etc it can push out about 400hp, what are your thoughts, and have any of you had any experience with these engines?
Name:	white chero front.jpg
Old 08-24-2003, 04:11 PM
Tim C's Avatar
Im new here too. I believe it should be easy to get 400+ hp from that motor. FE and FT engines have alot of interchagable parts. If it is a FT 360 and not a 361 (Edsel Motor), then you could easily make that engine a 390. A 360 is a 390 block with a 352 crank. You could swap in a 390 crank, rods and pistons balancer and Flywheel and have a 390. The timing cover might be different because the FT cranks had a larger front shaft. If the motor is an FE 360 the same info above applies, but the crank front shaft should be the same so the 360 timing cover, balancer and flywheel should work. The way to tell between the FT and FE engines is to check the crank. FT cranks were forged steel and are externally balanced at the Flywheel. FEs used a nodular iron crank and were internally balanced. The front of the crank on a FT engine is 1.75 inches in diameter, while the FE crank is 1.375 inches diameter.
Im running a 390 in a 67 Fairlane with a four speed. I have Edelbrock performer RPM heads and intake, the cam is a lunati 07503 (235* at .050, .560 lift, 108 lobe seperation), trw forged pistons, 12.5:1 compression, a 950 Holley and long tube headers. I am still building the car so I havent run it at the track or on a dyno yet, but I know of others with a similar setup dynoing 450+ hp and close or more than 500 lb-ft of torque. When I finish the car (hopefully by the end of the year), I will post some numbers.
For good information on the FE and FT engine families, including interchanabilities, I suggest you pick up the High Performance Ford Engine Parts Interchange by George Reid, published by SA Design, Part number SA56 ISBN: 1-884089-33-X. I got it at a local book store, but you could find it a www.cartechbooks.com.
Tim
Old 08-25-2003, 04:14 PM
Moby302's Avatar
Psychotic
Tim
Thanks for the reply, my better half just bought me that book you mentioned and I have been going thru' it, very good info in it. We have also got a 66 Fairlane, (Canadian build) based on the Galaxie full size Ford platform, no engine at present but will either put a inline 6 in or get a V8 for her, also a 69 Oz Fairlane, same story, no engine, 72 Oz Fairlane with a 351C, undergoing teardown, a 71 Mustang with 302, undergoing extensive body repair, trying to find some good metal in all the rust to weld on to, a 69 Oz Ranchero, 302 in, with a bit of a engine knock, next one due for teardown, the 72 'chero mentioned, a 70 cougar 351C, and 72 cougar 351C, 70 Holden Manaro 308, undergoing body and engine teardown. Hmmm, now I am depressing myself, looking at all this work to be done.
Your 67 Fairlane sounds like it is going to be a real mean car when you get finished, please keep me updated on the progress. Can we post pics here? I would like to see a pic of your Fairlane.
We have kind of got a 5 year plan going with our lot, hopefully get one finished a year.
