Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Block help
Thread: Fuel Block help
Old 06-10-2012, 09:25 PM
1971BB427's Avatar
1971BB427 1971BB427 is offline
Question; do you have a pressure regulator also? I always use a regulator and a pressure gauge, as it's good insurance against carb problems, even if you're running a mechanical pump, and a neccessity for an electric pump!
I run my tunnel ram and twin carbs through the regulator, then use one of the regulator outlets for my gauge, and the other goes to my fuel block. My fuel block is a 3 port, so I run in and two out.
I'm afraid of plastic line, so I'm running metal lines on mine.
If you mount it on the firewall you'll need a flexible section from body to engine, but after that I'd do aluminum or steel line.
