Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Block help
Thread: Fuel Block help
Old 06-11-2012, 06:50 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 1971BB427
Question; do you have a pressure regulator also? I always use a regulator and a pressure gauge, as it's good insurance against carb problems, even if you're running a mechanical pump, and a neccessity for an electric pump!
I run my tunnel ram and twin carbs through the regulator, then use one of the regulator outlets for my gauge, and the other goes to my fuel block. My fuel block is a 3 port, so I run in and two out.
I'm afraid of plastic line, so I'm running metal lines on mine.
If you mount it on the firewall you'll need a flexible section from body to engine, but after that I'd do aluminum or steel line.
Is this the engine in the gasser? That car is choice!
Not picking on you, but any worries the fuel block being mounted that way will fatigue the fuel lines? What is the gauge for/hooked to? I don't see any attachment for it.
