-   -   Fuel Block help (http://www.hotrodders.com/forum/fuel-block-help-220064.html)
1937MoPar 06-01-2012 12:49 AM
Fuel Block help
I have a tunnel ram set up with two four barrel holleys. I need to purchase a fuel block, but how many ports will I need on the fuel block? thanks guys!
35WINDOW 06-01-2012 07:15 AM
IMHO, A lot of it depends on how you are going to plumb it-are you planning a return line? If not, a regular "Y" block should do it, and I would size my Fuel Line by how much H.P.--6 up to, say, 500 h.p., and -8 up to 850-950, -10 above that-
http://www.russellperformance.com/mc...t_blocks.shtml
1937MoPar 06-04-2012 10:01 AM
I purchased 3/8 red clear fuel line, and was planning on running a 4 port Offenhauser fuel block.
35WINDOW 06-04-2012 10:44 AM
Why a 4 port? Are you going to plumb a Fuel Gauge or something? Why not three-one for inlet, two for outlets-
http://www.otbgear.com/2-Port-finned...og-P22C23.aspx
1937MoPar 06-07-2012 08:05 AM
Mounting he fuel block in the high center of the firewall. Fuel line from the fuel pump plumbed through the port underneath the fuel block, then the two holes on the front would plumb the clear fuel line to the 2 carbs.
opinions?
Mojo56 06-07-2012 10:22 AM
No problem with the extra ports but be very careful of what red fuel line you use. The common Chinese stuff that joints like Speedway sells are prone to early failures... I have heard of several engine fires using that stuff.
http://www.fordbarn.com/forum/showthread.php?t=72958
There are reputable sellers hawking good quality line... ask around and see who has the best. It looks real cool, and is very nostalgic, but the wrong stuff can kill your ride in a hurry.
WDCreech 06-07-2012 10:24 AM
If you ever plan on taking it to the track, tech will tell you that you can't use that clear plastic line for fuel.
65 Imp SS 06-08-2012 06:40 AM
I don't think a fuel block on the firewall will pass tech either.
1971BB427 06-10-2012 09:25 PM
Question; do you have a pressure regulator also? I always use a regulator and a pressure gauge, as it's good insurance against carb problems, even if you're running a mechanical pump, and a neccessity for an electric pump!
I run my tunnel ram and twin carbs through the regulator, then use one of the regulator outlets for my gauge, and the other goes to my fuel block. My fuel block is a 3 port, so I run in and two out.
I'm afraid of plastic line, so I'm running metal lines on mine.
http://img.photobucket.com/albums/v6...y/DSCF3302.jpg
If you mount it on the firewall you'll need a flexible section from body to engine, but after that I'd do aluminum or steel line.
cobalt327 06-11-2012 01:41 AM
You are correct, it won't. Max 12" of rubber fuel line for the entire fuel system. Braided lines do not count as rubber.
cobalt327 06-11-2012 05:50 AM
Is this the engine in the gasser? That car is choice!
Not picking on you, but any worries the fuel block being mounted that way will fatigue the fuel lines? What is the gauge for/hooked to? I don't see any attachment for it. :drunk:
http://www.hotrodders.com/gallery/da...dium/gauge.jpg
1971BB427 06-11-2012 01:17 PM
Not too worried, as there's a bracket attached to the back of that block. The gauge is plumbed into the intake to read vacuum. Yes, this is my Austin gasser.
1937MoPar 06-11-2012 07:27 PM
I want to do something like what Milner had on his 32 Ford. Please google pictures
1937MoPar 06-12-2012 04:50 PM
http://unofficialamericangraffiti.we...1932-ford.html
look at the firewall
cobalt327 06-12-2012 05:12 PM
Is there still a question here somewhere?
