Fuel block set up (american graffiti)
Does anyone know what kind of fuel block Milners 32'Ford Coupe had from the Movie American Graffiti? How was it plumbed? thanks!
I did a little googling for you, If you go to http://www.kipsamericangraffiti.blog...hing-in-valley, you can find pics of the coupe. If you scroll down about 5 pics you'll see a pretty decent layout of the engine with the fuel log sitting on the alum. firewall just above the engine. It has 4 clear plastic fuel ines coming down to the 4 - 97's. Might take you a little huntin' but it there.
edit....for some reason it won't print the entire website address ??? anywho after to continue it.....blogspot.com/2011/cars-32coupe-fastest-thing |
my experience
the old clear or red tinted fuel lines soften with heat, and old 97;'s were known for leaking fuel...and the plastic melts very easy in an engine fire. I KNOW> But they looked neat and the clear-red tint spark plug wires to match would also melt when too close the the exhaust.
In case there was any doubt about the hose routing:
One line per carb? Or two? (2 Four barrels)
But Holley "dual feed" carbs (center hung "cathedral" or "Dominator" style fuel bowls) usually use a two into one fuel line attached to the carb, like shown below: ![]() Dual feed carb line, these come in all kinds of versions; braided lines, AN lines, lines w/fuel pressure gauges attached, center inlet, rear inlet, you name it. But they are almost always some type of 2 into 1 design, as seen below: ![]() ![]() Holley w/side hung floats and single fuel inlet Some Edelbrock carbs like their AVS series can be plumbed for dual lines as well, but they usually just have a single inlet. Obviously four 2-barrels like the movie car had originally are going to have one inlet each, four lines total. Last edited by cobalt327; 06-15-2012 at 03:18 AM. |
BTW, if dual fours are going to be used, I'd just forget about originality and run a dual outlet fuel block. They have them in the same style as the 4-holer above. |
Falfa's car was the one used in 2 Lane BT; and with that 454 in there, it woulda laid waste to that 5 window. Of course without James Taylor there to 'tune the holleys'; Milner may have had a chance. The Milner Coupe sat around the movie lot for a long long time, and people used to take souvenirs from it
| Hotrodders.com Art Contest "American Graffiti" Anything Goes Voting Starts Now. | Only Racing | Hot Rod Art | 20 | 02-08-2011 07:19 AM |
| American Graffiti CO. | Derkyb | Hotrodders' Lounge | 7 | 03-19-2008 02:46 PM |
| * build pics * two lane blacktop 55 / American Graffiti 55 car | Mustangsaly | Hotrodders' Lounge | 14 | 02-02-2008 04:35 PM |
| in progress A Friends 55 Chevy American Graffiti Build (pics) | Mustangsaly | Hotrodders' Lounge | 14 | 03-28-2007 07:18 AM |
| American Graffiti | WilderRods | Hotrodding Basics | 13 | 01-30-2005 12:44 PM |
