Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 08-07-2007, 09:14 PM
Mel Smith Mel Smith is offline
Fuel Cell
The outlet on my fuel cell is loose and it is leaking, is there any way to tighten the nut on the outlet or do I have to buy a new fuel cell. The outer nut just spins around and I don't see any way to get inside to hold the interior nut while tightening the outside nut. Any help is appreciated.
Old 08-07-2007, 09:30 PM
techinspector1 techinspector1 is offline
Senior Curmudgeon
 techinspector1's barnstar
Wiki Edits: 125
re: Fuel Cell
They figured out how to do it when the cell was manufactured. Probably with a socket, a couple of u-joints and long extensions. Have your bride hold the flashlight.
Old 08-07-2007, 09:47 PM
home brew's Avatar
home brew home brew is offline
Just Plain Nashty
 home brew's barnstar
re: Fuel Cell
Don't use a match!!!!
Old 08-07-2007, 09:50 PM
powerrodsmike's Avatar
powerrodsmike powerrodsmike is offline
oddroddermodderate-tor
 powerrodsmike's barnstar
Wiki Edits: 126
re: Fuel Cell
I have had a couple do that and I was lucky, the filler hole was somewhat large...so I recruited my daughter ..who has some really skinny arms....(one more way she doesn't resemble me ) ....and with those skinny arms she was able to reach inside with a wrench...
One time I welded a cheap wrench to a long piece of 1/4" by 1" flat bar and bent it around to fish inside the tank and get on the nut...
You could try to pound an easy out into the fitting and hold it from turning from the outside while you tighten up the nut..
Or grab it down low below the external threads with some needle nose vise grips and hold it from the top like that...
Or try a butterfly impact and shock the nut down tight by short bursts on the trigger..
Ok that's all I got.
Hope it helps, mikey
BE different....ACT normal.
Old 08-08-2007, 12:12 AM
full Cell
Any body know the size of the interior nut, is it the same size as the outside?.This cell has foam inside, I don't know if I can get the foam out of the way. Not a bad idea about some small hands inside holding the nut.
Old 08-08-2007, 12:32 AM
Wiki Edits: 126
re: Fuel Cell
Usually those bulkhead fittings have the same size inside and out.
mikey
Old 08-08-2007, 04:00 AM
Blazin72's Avatar
Blazin72 Blazin72 is offline
Realign your connecting rods..
 Blazin72's barnstar
Wiki Edits: 19
re: Fuel Cell
Mel, I had a similar problem. I had to remove the filler then remove the foam and reach my hand inside. How is your fuel cell constructed, is it a plastic cell or aluminum? Mine was plastic and had a metal ring with a gasket bolted to the filler opening. I removed the ring and the hole was big though to fit my hand through.
Old 08-08-2007, 07:27 AM
kruzr's Avatar
kruzr kruzr is offline
street rods forever
re: Fuel Cell
Try wrapping duct tape on outlet fitting,to protect threads.Grab fitting with pliers then try tighten nut,I,ve had success with this,but not all situations are the same.good luck
Old 08-08-2007, 09:16 PM
Fuel Cell
Thanks for all the input guys. My son came over tonight and he was able to get on the inside nut with a long handle 1" open end wrench and was able to hold it while I tightened the outside nut. Problem solved. Thanks again for your answers.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Fuel Cell"
Installing a fuel cell gilliganspl General Rodding Tech 1 04-11-2007 08:22 AM
carburetor leaking; fuel tank needs cleaning islandman General Rodding Tech 7 03-17-2007 06:03 PM
custom floor and fuel cell 16grem72 Interior 1 02-08-2005 02:30 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
