Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Cell
Thread: Fuel Cell
Old 08-08-2007, 04:00 AM
Blazin72's Avatar
Blazin72 Blazin72 is offline
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
Mel, I had a similar problem. I had to remove the filler then remove the foam and reach my hand inside. How is your fuel cell constructed, is it a plastic cell or aluminum? Mine was plastic and had a metal ring with a gasket bolted to the filler opening. I removed the ring and the hole was big though to fit my hand through.
