Don't know if you want to change things at this point but the system would be a lot better with the regulator up close to the carb. Right now you are cutting the pressure down when the fuel is still a long ways from the carb, meaning all you are pushing up the line is low pressure.
You want to have full volume and pressure to up near the carb and THEN cut the pressure down with a regulator and send the remaining back to the tank. Those hardware store brass fittings are typically quite restrictive(small bore thru hole), especially that hard 90° on the return port of the regulator. Hope those are coming off when the real line goes on. |
| Recent General Rodding Tech posts with photos |
| fuel return line - 79 chevy 1/2 ton | Torque454 | Engine | 7 | 02-24-2010 11:32 PM |
| Could It be my Fuel Tank / Fuel Line? | 10mikeymike | Engine | 4 | 09-17-2008 02:25 PM |
| fuel line question | dboyett | Engine | 3 | 11-09-2006 04:38 PM |
| Simple fuel line question | red_rider52 | Engine | 8 | 03-07-2005 10:08 PM |
| Body Line | Man586 | Body - Exterior | 6 | 08-20-2004 08:24 AM |
