Fuel Cell-Tube Type Fuel Level Sending Units - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2005, 02:45 PM
Stupido1's Avatar
74 NovaSS
I am looking at Fuel Cells for my 1974 Nova with a SBC 350. The gas tank is leaking so I figured this was a good excuse to get a Fuel Cell.
These Fuel Cells i am looking at come with or without fuel-sending units aleardy installed. Does a Fuel Cell need a sending unit? Do I install one if the cell doesn't come with one? Am I better off buying a cell with the sending unit? I am kind of in the dark here about this. If someone could help out, that'd be great.
Old 06-11-2005, 03:42 PM
camaroman7d's Avatar
Perfect timing I am in the process of building my own fuel cell. So lets see if I can help.
If you want to know how much gas is in the cell, then you need a sending unit. There are a lot of cells that come with sending units installed. Usually the 16 and 20 gallon sizes have that option.
There are different types of sending units, the tube type is perfect if you plan to use foam in your cell (or buy a cell that is foam filled). The foam controls slosh and helps keep the fuel where you want it. The lever type (similar to a stock sneding unit) will not work if you use a foam filled cell. The float will get caught on the foam.
You can also buy the sending unit seperately and dependning on the type they cost between ~$40 and $80. Yes, you can add one to a cell that doesn't have one.
There are also different rated sending units (in ohms). For your Chevy you need a 90ohm sending unit (0-90) for your gauge to read accurately.
I hope that helps.
Royce
Old 06-11-2005, 05:55 PM
Stupido1's Avatar
74 NovaSS
so, let me see if I am hearing this right. If you don't need to know how much fuel is in the fuel cell, then you do not need a sending unit?
Old 06-11-2005, 06:31 PM
coldknock's Avatar
Yup, and if you want to know how much is in it you'll need a sending unit. That is if you don't want to open the trunk, pop the cap and dip a stick in it every other day.
Larry
Fuel Pump Not Sending Gas To Carb Why?? Its Not Electric Fuel Pump???? zeeman19 Engine 7 02-13-2007 03:17 PM
fuel level sending unit question mike bryan Electrical 3 12-04-2004 10:48 AM
Various GM sending units . . . need help. Siggy_Freud Electrical 2 09-25-2004 06:40 PM
fuel level sender?? nova33 Electrical 3 02-08-2004 04:47 PM
Fuel Cell location? jamnut General Rodding Tech 0 06-15-2003 10:12 AM
