Fuel check valve? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2013, 11:36 AM
Madmax305's Avatar
Fuel check valve?
Hey Guys, I have a 67 El Camino with a SBC 350, Edelbrock carb, headers, lumpy cam, etc. The car runs great. It is not a daily driver, it will sit days to weeks at a time. The car fires right up when it is driven daily. Here is my question, when the car sits for longer than a week, it will take about 30 seconds of cranking for it to start. Is it possible with these cars to install a one way fuel check valve in the fuel line? Will it hurt anything?
Old 07-14-2013, 12:31 PM
techinspector1's Avatar
Wiki Edits: 326
Fuel in the bowl cannot flow uphill past the needle and seat. The fuel loss you're experiencing is likely evaporation out the vent due to high alcohol content in the fuel or a leak, allowing fuel to dribble out of the bowl and into the intake manifold.
In the past, I have rigged up a low-cost electric fuel pump on a separate electrical circuit, using a momentary push-button switch, to top off the bowl(s) before lighting up the starter.
Old 07-14-2013, 12:42 PM
lakeroadster's Avatar
Hot Rods are Built, not Bought
Last journal entry: Lakeroadster's '31 Model A Tudor
Max I have the same issue on (4) cars with a variety of carbs: (2) Holley's a Quadrajet and an Edlebrock. A buddy of mine added an electric fuel pump (as Tech Inspector mentioned above) and it worked quite well.
For me I just let them crank till the mech. pump fills the bowls.
Old 07-14-2013, 12:49 PM
Wiki Edits: 326
Problem with this approach is that the cam is getting no splash lube all the time the starter is being ground on. This will likely spell death for flat tappets after a while.
Old 07-14-2013, 01:05 PM
I have heard other folks say that also.
If I combine how long I have owned the 4 cars I mentioned above I have about 20 years of history starting them this way, all without a problem.
The Valvoline VR1 oil that I use no doubt helps...
Old 07-14-2013, 01:49 PM
Madmax305's Avatar
Same here, I use VR1 as well. So I have an option of wiring in an electric fuel pump for the long periods of sitting, what about a check valve in the fuel line near the tank to help keep the fuel trapped there for the extended periods of sitting?
Old 07-14-2013, 01:57 PM
It's not leaking back down the fuel line, it's evaporating out of the carb. Not much you can do. If you can find "non-ethanol" fuel it will help.
Old 07-14-2013, 02:13 PM
Madmax305's Avatar
It's not leaking back down the fuel line, it's evaporatingar out of the carb. Not much you can do. If you can find "non-ethanol" fuel it will help.
Ok, we'll that makes sense. I found electric fuel pumps at summit racing for $35 -$50 which would appear perfect for this problem. They show 4-7 psi of pressure. Would I need a pressure regulator? Would this be installed near the tank, I presume I can keep the mechanicle fuel pump?
Old 07-14-2013, 02:24 PM
Yes to the regulator.... or bad things will likely come your way and yes to keeping the mechanical... but there's more to the story. Here is a link to my buddys build thread. He installed the "carb. priming extra electric fuel pump" and did an excellent write up, start at post #478 on page 20. Markeb01 Build Thread - Page 20 - The 1947 - Present Chevrolet & GMC Truck Message Board Network
A smart man learns from his own mistakes, but a wise man learns from the mistakes of others....
The Following User Says Thank You to lakeroadster For This Useful Post:
techinspector1 (07-14-2013)
Old 07-14-2013, 02:41 PM
Madmax305's Avatar
Thanks for the link, that was very helpful....
Old 07-14-2013, 05:15 PM
Madmax305's Avatar
Can you recommend an electric fuel pump that will work with the stock mechanical pump? I found a few on Summit racing that were in the $40-$60 range.
Old 11-19-2013, 09:30 PM
bullheimer's Avatar
NEVER use credit cards!
hi. i thought i posted about this same thing but i couldn't find it. anyway on the cherokee forum i found a thread on this same thing. for me its that stupid *** Edelbrock carb i wish i'd never bought. but some have the same prob with other carbs. go figure. never had it with my holley.
go to wwwbmaparts.com and ask for BMW part number 16149068988 and it will come up with one for a 3/8" fuel line for $14. i thought i looked but it must not have been too good cause all i did this time was google check valve and viola!
just don't buy one tomorrow cause that's when i'm gettin mine. shipping should be another $3-5. hope this fixes my issue as it killed my last battery.
Old 11-20-2013, 11:40 AM
bullheimer's Avatar
well great. i cant edit my above post. wtf is going on around here?
anyway, got an email from bma which said, TOUGH STUFF, we no longer have that part available. however i did get this:
You could buy one of our U600 series brass check valves and either put on the barbs yourself or I could quote it complete. If you want to go with smallest/cheapest available, would be the U613-2-2PP. Valve is $11.05 plus shipping. Or let me know if you want complete with barbs.
Valve Check, Inc
NOTICE that this is not bma.com but Valve Check, Inc peace out home fries.
Old 05-11-2015, 10:35 AM
bullheimer's Avatar
just want to say this about that: Sat. over the weekend when i was at the Boat Shop buying some Star Bright to remove the mold on my paint, i noticed an Evenrude "Anti Siphon" valve on the shelf. NOT having gone out and bought the above part (my debit card "purchase" got declined at the time", i bought it immediately!! i had to go to napa and get a union and another male nipple to make it work, since nobody seems to carry a female nipple, but FINALLY i won't have fuel siphon back into my tank anymore! And also THAT was what was also making the inside of my truck stink like gas everytime i got into it!!! Dont ask my why because my tank is not in the cab anymore, but it used to REAK! funny how you can look all over creation for a one way check valve and nobody has one, but you look for an anti siphon valve and there it is right in front of your face. amazing.
Any benefit to running a check valve in the fuel system? ForceFed86 General Rodding Tech 1 03-04-2013 06:44 PM
Fuel Line Check Valve Ted's37 Engine 3 12-14-2011 07:51 AM
Residual Check Valve Dino383 Suspension - Brakes - Steering 2 01-30-2011 10:09 AM
how to check valve seal and valve guides daveid Engine 3 11-06-2007 06:02 PM
Check valve engine?!?!? chevyguy Engine 4 08-19-2003 01:47 AM
