fuel delivery problem has me stumped - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2006, 06:31 AM
dripcandles's Avatar
I turn the key and the motor just cranks unless I dump gas in the carb of my 78 Cutlass Brougham(260 V8), then it will start, and if I dont let it stall for a few minutes it will run fine all day, and even restart the next day without any problem. If it sits for more than a few days I again have to dump gas in the carb to get it going again. I changed the fuel pump, the fuel filter, and I tried loosening and tightening the gas cap, and I checked that the lines in the engine compartment aren't kinked. If anyone has any ideas on where I would look next I would greatly appreciate it!
Old 05-16-2006, 07:25 AM
after 2 days, engine off, stick your head over the carb and manually work the carb linkage
you should be able to see the primer pump "squirt" gas like a water pistol into each primary every time you release and re-open the linkage if your carb is working correctly
Old 05-16-2006, 09:57 AM
johnsongrass1's Avatar
Race it, Don't rice it!
My guess the choke doesn't work correctly.
Old 05-16-2006, 10:01 AM
Jmark's Avatar
For sure in the carb. Carb draining out internally, accelerator pump not working at all, choke out of adjustment.
Old 05-16-2006, 01:54 PM
Thanks for the advice, I already started looking for a new carb. (if I rebuilt mine myself it would probably never work again!)
Fuel Filter Location leejoy Engine 7 05-04-2006 08:50 AM
Nitrous Problem, Maybe fuel pump? esears Engine 7 05-02-2005 05:21 AM
fuel pressure problem...help Im stumped! Docs91RS Engine 3 08-20-2004 02:42 PM
Dumb Question on Fuel Delivery Dottrz Engine 4 09-04-2003 01:32 AM
new fuel delivery system advice needed dusterbd Engine 4 06-03-2003 06:13 PM
