fuel door through the wood bed - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2011, 06:58 AM
StudebakerDean
hey all, I have to turn to the pros on this one. I searched, but im not having any luck.
anyone know what I can use for a fuel door, w/ some fuel filler pipe behind it, to go through my wood floor in the bed of the truck?
I moved my gas tank to the rear of the truck. The fuel pipe entry to the gas tank points straight up. I want to drill through the wood bed with a metal type fuel door, screw it to the bed, and rubber fuel line connect to the tank below.
Ive seen hundreds of photos of fuel doors, but do they have a few inches of filler pipe behind them to connect to my tank?
has anyone done this?
Old 08-01-2011, 08:42 AM
dinger's Avatar
Drake sells flexible fuel line, I used it on my coupe. I used the Hagan gas door, here
My buddy makes them with exhaust tubing, welds them to a plate, then mounts the door over that, does a lot in the fancy P.U. beds.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Fuel Door for 37 Ford? 37 in Salem Body - Exterior 1 12-17-2007 07:24 AM
Gas/Fuel Door 57halfton Body - Exterior 7 07-15-2007 07:42 AM
1936 Oldsmobile Door Wood mkcsbrown Interior 3 08-01-2006 10:10 PM
'36 Olds Door wood mkcsbrown Body - Exterior 1 07-24-2006 08:21 PM
1950 Hudson Fuel door hedonite Body - Exterior 3 12-19-2004 12:43 PM
