Fuel Economy/Tuning - Olds 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2005, 03:08 PM
fearsomefairmont's Avatar
Hi Folks,
Being that I am new to carburated vehicles, I was wondering what kind of gas mileage I should expect from my '72 cutlass.
It has a mildly worked over 455, Hooker Comp Headers, Edel. Performer manifold, Accel HEI distributor, Edel. 750 carb, and unknown mild cam. It is a '73 J-head motor and the trans is a built TH-375 with a 1500 (stock) converter. The rear end is a 3.08 open.
I get around 9-10 mpg city and 12-14 freeway. Is this what I should expect? It is tolerable to me, but the carb seems to have a mild off-idle flat spot, and a pause before the secondaries come in if I whomp on it. It lays about 30 feet of rubber ON DEMAND though, which I am quite satisfied with.
Any ideas to better tuning? Timing recommendations? Perhaps a metering rod replacement?
Since I will be modifying the motor later, I am leaving everything as is. Later upgrades will be forged pistons, mondello intake, and Edel. Aluminum heads.
Thanks for your input,
Andy
Old 03-06-2005, 03:32 PM
4 Jaw Chuck's Avatar
Sounds pretty good to me, might want to fine tune the idle mixture with a vacuum gauge...might help the off idle lean spot.
— Han Solo
Old 03-06-2005, 03:50 PM
Nailhead2x4's Avatar
....well I'd say that is not bad considering you're talking a usa gallon, up here in canada the imperial gallon would give you about 20% more in milage which would make it 15-17 highway , so you are about right with today's crappy fuel. Could try bump up the timing a couple of degrees and see it don't ping, may give you a hair more distance.
olds 455 oldscutlass General Rodding Tech 7 01-01-2005 11:34 AM
olds 455 oldscutlass Engine 6 12-13-2003 12:03 AM
Olds 455 vs. Pontiac 455? bildo95 Engine 3 06-27-2003 04:53 PM
olds 455 build up oldscutlass Engine 1 06-24-2003 08:57 PM
74 olds 455 little line on fuel pump 225buick Engine 2 04-09-2003 08:23 PM
