Fuel / emmission line - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2011, 04:34 PM
david-b's Avatar
Dave is THAT guy
Quick question... today I pulled the cruise control and emmission canistor from my 75 Monte Carlo. It has the emmission line coming from the gas tank up to the engine bay canister. When I pulled the emmissions from 95 Eagle Talon, I was told that I could cap off the line coming from the tank with a vac cap or just have it dump down under the car. I capped it, and never had an issue. Can I do the same with the Monte, or do I need to do something special?
Thanks fellas!
Old 08-29-2011, 06:23 PM
75gmck25's Avatar
If its a vent line it needs a to stay open unless you have switched to a vented gas cap. If you cap it tightly there will be no way to let air into the gas tank as fuel is drawn out, and no place for fuel vapor to expand.
Bruce
Old 08-29-2011, 09:37 PM
david-b's Avatar
Dave is THAT guy
Bruce
Thanks, makes sense. I'm assuming these didn't come standard with a vented cap? And is that something I can get at AutoZone or any parts store? I've never looked for a gas cap before honestly.
Old 08-30-2011, 04:40 AM
75gmck25's Avatar
For a vented cap you will probably have to go back and find one for a vehicle in the late sixties or early seventies. I'm not sure what year they started using the vapor recovery system with the filter canister.
Bruce
Fuel Injection Fuel line Plumbing william27103 Engine 9 06-10-2011 05:22 PM
Fuel disappearing from fuel line at carb K and K Engine 24 08-14-2010 04:30 PM
Copper Brake Line,Fuel Line redlightning General Rodding Tech 6 08-23-2006 08:50 PM
FUEL LINE & TRANS LINE SIZE/TYPE leejoy Hotrodding Basics 7 11-29-2005 10:59 PM
efi fuel line sizing / fuel pump Blob Engine 2 09-25-2005 12:25 PM
