Fuel Filter - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2006, 08:17 PM
Fuel Filter
I'm installing a sump and Holley blue pump. I'm plumbing the fuel system with 8AN. What do you think about this fuel filter between them? I figured since it's 8 AN in and out and filters 85 microns it would be a good first filter. I have another 10 micron 6AN Earles filter between the regulator and carb. Any thoughts? Thanks
http://store.summitracing.com/partde...0&autoview=sku
Old 05-04-2006, 07:49 AM
Technical Support Barry Grant
Your link isn't working, but you need to make sure the flow rate on the filter doesn't restrict the flow of your fuel pump.
Old 05-04-2006, 08:05 AM
Sorry about the link, this should work better.
Old 05-04-2006, 08:20 AM
1931 steve's Avatar
Last wiki edit: How to rebuild an engine Last photo:
Wiki Edits: 4
This is what I used. If you need part numbers I can get them for you.
Steve
Name:	Fuel tank fix 1.JPG
ID:	11954   Click image for larger version
Name:	Fuel tank fix 2.JPG
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
where the fuel filter and help with missing tsw5013 Engine 10 03-02-2006 08:23 AM
fuel filter astrops Engine 4 05-13-2004 11:11 PM
questions about fuel system for a 434 small block chevy tony350ss Engine 4 08-27-2003 11:02 AM
Holley carb experts? Others? Why is my truck's fuel bowl being sucked dry? MuscleTruck Engine 5 05-23-2003 12:36 AM
