-   -   fuel filter (Best Place) to install (http://www.hotrodders.com/forum/fuel-filter-best-place-install-94807.html)
39chevy 07-30-2006 08:48 AM
I am installing a electric fuel pump about 2 ft from my gas tank and I do have a glass fuel filter about 1 foot before my dual carb! Should I install another fuel filter before my electric fuel pump, My tank is brand new anyway, Poly type? Thanks again in advance, Dana
Rick 5150 69 07-30-2006 09:13 AM
One filter should suffice,...but the glass filter has caused more fires than you can imagine, IMO get rid of it, and use a steel style canister in a out of site location!
hotroddr 07-30-2006 09:17 AM
fuel filter
I'm with Rick. I just used a canister from Summitt, mounted it on the framerail with a lever type shut off between the tank and canister. Bill :)
Tech @ BG 07-31-2006 08:05 AM
It is allways best to have a filter before the pump to prevent any debris from getting into the pump itself, and then having a final filter up at your carburetor to prevent any debris from the pump or lines from getting stuck in your carburetor.
