Fuel Filter - Frame mounted - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-16-2006, 03:14 PM
Do you really think anyone would pay the Ford Parts Counter price for this fuel filter when a top quality WIX filter is available at any O-Reilly's or CarQuest store?
The parts are available under any junkyard Marquis or Vic and the filters at the parts stores. Just do it!!
  #17 (permalink)
Old 12-16-2006, 05:46 PM
joe k's Avatar
Jegs has a canister type fuel filter with replaceable elements the part # is 555-15170
  #18 (permalink)
Old 12-17-2006, 01:36 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Yeah ... that one looks like it might be OK.
Jegs
I suppose that it might be a good idea to order and carry a couple of spare elements.
That was what I liked about the one that I had been talking about ... elements are cheap and easy to find.
Thanks!
  #19 (permalink)
Old 06-24-2009, 01:18 PM
66GMC's Avatar
Fram HPG1
  #20 (permalink)
Old 06-24-2009, 02:10 PM
streetrodderbn's Avatar
Certifiable Streetrodder
I always use the fram hpg-1, you can get filters at any good parts store, they are the part # hpgc-1
  #21 (permalink)
Old 06-25-2009, 10:27 AM
dinger's Avatar
These are manufactured in my neck of the woods.
http://www.system1filters.com/fuel_filters.htm
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
  #22 (permalink)
Old 06-25-2009, 02:53 PM
fast68's Avatar
likes chevy trucks & boobies
wow i have never seen such a fuel pump ever
when did gm ever use these?
i have a hrd time believing that
unless it was way back in the 30s or 40s or something?
that style pump is 55-up though
odd...
never seen a removable element fuel filter either ever..
  #23 (permalink)
Old 07-04-2009, 08:20 PM
66GMC's Avatar
odd...
What???
Next thing you'll be telling us is that you've never seen vacuum wipers either! LOL (Just teasin')
Lots of older vehicles used to use a sediment bowl and / or a cartridge style filters for both motor oil and gasoline.
Lot of Fords used a fuel pump mounted cartridge elements (just like the ones pictured in my original post) on passenger cars up until the early to mid 60's. Ford continued to use them on the light trucks for about another decade, and on the MD / HD series trucks with gasoline engines until the late 70's
GM used them on their MD / HD trucks as well ... but they were commonly remote mounted on the frame. (See post #11)
Go here (Wix Filters), and then click on "All Applications ". You'll discover that the "big 3" as well as many other mfr's used this same filter.
As I've already said ... I like the idea of having a sediment bowl / filter between the tank and my electric fuel pump. That sediment bowl also acts as a water trap.
I just sold a $600.00 marine carb the other day to a guy that had experienced the effects of freeze up ... a cracked front float bowl.
I shouldn't have that concern with mine ... as It is destined to become a winter "garage queen" if and when I ever get it finished.
  #24 (permalink)
Old 11-01-2009, 06:24 PM
Jim Rockford's Avatar
World Famous VF-14
Last journal entry: Cleaned it up...
Originally Posted by 66GMC
If those are anything like their crappy *** oil filters no thanks.
  #25 (permalink)
Old 11-01-2009, 09:31 PM
66GMC's Avatar
Well, if it makes you feel better ... throw away the crappy FRAM paper element and replace it with a WIX 33900R.
I'm not a huge Fram fan either, but Wix doesn't make a complete assembly.
It does seem to be a fairly popular design, because Summit's #G1503 and Jeg's #555-15172 both appear to be identical.
  #26 (permalink)
Old 11-01-2009, 10:03 PM
Wiki Edits: 31
the fram HPG-1 was OEM for some diesel engines b4 it was turned into an aftermarket fuel filter. I have 1 I bought for my Falcon, but being that's gone now, I'll use it on my rat rod
Fuel Filter 72Orange Engine 3 05-04-2006 09:20 AM
What is the best way to run fuel lines from a sump. novadan Engine 2 10-04-2005 12:08 AM
Designing the fuel system 66Caprice Engine 9 05-12-2005 03:57 PM
Bad fuel filter? 5.0Towncar Engine 6 03-14-2003 04:56 AM
Fuel Filter 5.0Towncar Engine 3 02-22-2003 04:17 PM
