Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fuel Filter - Frame mounted
Old 12-15-2006, 03:35 PM
aka Duke of URL
I'm confused (as usual). You describe a frame mount canister style but show a pump mounted filter asm.
What are you working on and do you want a replaceable canister style or an inline style? Gas or diesel? A sediment bowl to me describes the style that had the glass bottom that you could see and drain the water from also. A water separator style is also available similiar to a spin-on oil filter with a drain petcock. OEM or aftermarket?
