fuel filter location? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2010, 10:17 AM
On a car with a stock mechanical fuel pump,does it matter if the fuel filter is before or after the pump?
Old 10-14-2010, 10:20 AM
Greg T's Avatar
www.krusinklassics.net
If you're only going to use one I would put it as close to the carb as possible. I always use one just before the pump and one just before the carb.
Old 10-14-2010, 10:34 AM
Yeah, what ^ he said. One before the pump prevents any little bits in the tank from sticking a check valve. One before the carb prevents a self destructing pump from crapping out the carb. One at the carb regardless of any others inline.
Old 10-14-2010, 11:31 AM
Last journal entry: It's getting there
I agree with Greg T and KMatch, but I would use hardline between pump and carb. There is nothing like a fire from a broken hose to really screw up your day.
Who hates NHRA's 12" rubber line rule? 454headache Hotrodders' Lounge 21 08-17-2010 07:48 AM
Fuel filter location on 2002 S-10 w/4.3 Chopt 48 Hotrodding Basics 4 05-10-2007 01:42 AM
Fuel Filter 72Orange Engine 3 05-04-2006 08:20 AM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
350 Chev - fuel filter / gallons per hour? Limey Simon Engine 5 10-24-2003 07:33 AM
