fuel filter in pvc line on sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-22-2008, 08:53 PM
i installed a 3/8 inline fuel filter in the pvc line on a sbc, it traps oil in the filter, and cut down on exhaust fumes, seems to run better and spark plugs are cleaner.
Old 05-22-2008, 09:09 PM
Jmark's Avatar
It should work for a while. I think you will find that in time, the filtering element will get saturated and you will end up pulling large dropletts of oil into the engine.
There are different ways to put on a seperator, I guess that's one. I've seen some guys use oil seperators from air compressors. They drip down and stay fairly clean. You can do a google search on "catch can" and "oil seperator" and get some cool home made ideas. A mason jar works good, or an older metal lid mayonaise jar too. Some way to "catch" the oil so it can drip back down is a plus too. Some i've seen have used steel wool inside a baby food jar, mounted upside down inside a mason jar, mounted to the lid and plumbed properly.
I have a "Condensator" on my truck, got it at an auction for 5 bucks. It's very old school, 60"s probably, but works great.
Here is a pic of it on a deceleration, the cloudyness is from the oil fumes. Pretty cool.
here is a different and newer version from Germany that is turbo friendly.
Old 05-23-2008, 08:14 AM
nope, just a gas filter on the pcv line isn't a best plan....
part of the carb's fuel metering is designed/calibrated based on basically "no" cfm velocity restriction thru the pcv port....
in a very short time the oil dirty filter will add cfm flow restriction...
yup, agree with Jmark, make a oil accumulator/collector and then improve your valve cover baffles till there is next to nothing in the jar
Old 05-23-2008, 04:01 PM
Dale
Did you notice that your fuel mileage has gone up since you installed your "Condensator" on your vehicle? They were good for up to 25% increase. I sold those in the 1980's and early 90's, I got $100.00 plus installation for them. $5.00 was a great deal. I paid $45.00 each when I bought them by the case. Dale
Old 05-23-2008, 04:29 PM
Jmark's Avatar
Dale, I did not ck my milage before or after. My main reason for trying it was it was cheap and I was curious how much oil was actually getting into the intake stream. While a half a quart that is now in the jar which spans about 10,000 miles is not much, it is interesting how much blow by an engine has.
Mine has the 3/16" hose on top for the air bleed. I understand how this could help milage on older sloppy running 50's carbs, but on todays injected engines, it will do more harm than good. I have my carb set pretty lean and don't need it any leaner so I just pinched it off.
I guess I could ck the milage now then unhook it and ck again, but I seriously doubt there would be any difference. Personally, I do not think there is any milage benefit from just seperating out the oil. But hey, I could be wrong.
Their site has "testamonials" but no solid third party verifyable test results.
Old 05-23-2008, 05:40 PM
Dale
This is the only fuel mileage device that was CARB approved in California that I know of. It does all that it claims and more.
Not only does it raise fuel mileage but due to the oil mist being removed,your engine will clean itself of carbon build up and engine will last longer. With the oil mist gone your PCV fumes that are totally fuel vapors will burn hotter causing the other fuel charge to burn more efficiently as only gasoline VAPOR will burn.
The Condensator came in 4 models A.B.C.and D. A was for 6 & 8 cyl carb engines, B was for 4 cyl carb engines both had the air vent. C was for fuel injected motors, this was the one I sold the most of as it would work on both carb and FI engines, and D was for diesels. Dale
WARNING Mr Gasket Fuel Filter Problems SilverFox2 Engine 11 09-08-2008 04:36 PM
Fuel Filter Location leejoy Engine 7 05-04-2006 08:50 AM
FRAM air breathers!!!! Robbie Engine 70 09-22-2005 05:52 PM
Fuel Injection Fuel Line Plumbing william27103 Engine 0 06-08-2004 10:31 PM
fuel filter astrops Engine 4 05-13-2004 11:11 PM
